01-13-2010 12:25 PM - edited 03-14-2019 05:06 AM
It seems the more that i research the more confused I'm getting. We are planning an upgrade of our Contact Center from 5.x to 7.x along with CUCM 6.x. I was told that BARS would be used to backup our current setup, but I thought that BARS only worked with 4.x. Can someone please set me straight.
Solved! Go to Solution.
01-13-2010 03:23 PM
As of CRS 5.x backup and restore functionality is embedded within AppAdmin. Traditional BARS, using CM as the BARS "backup server" and CRS as a "backup target", is no longer supported. For more information take a look at the "Backing-up and Restoring Data" section in the Administration Guide.
Andrew
01-13-2010 03:23 PM
Andrew
01-14-2010 07:25 AM
Thank you Andrew this is exactly what I was looking for.
BTW I worked on a ship for a year called the Andrew J. Higgins how about that..
Again Thanks
