CSM 3.3.1 : TCP port Timeout for special ports
martin.payette
I would need to create new TCP ports in CSM to be able to increase the timeout (24 hrs or 86400 sec)
Would it work if I create a new inspect? is it the best way of doing this?
I know we cannot use the "timeout con" attribute (because it will modify ALL TCP timeouts)
Best regards,
Panos Kampanakis
Yes that is what you want to do. You don't want to change the tcp global timeout.
It will be put in a new class map under a policy map.
It is the "set connection" option under the class-map.
It is under setting the Modular Policy Framework options for connections in CSM.
I hope it helps.
PK
Hi PK,
thank you for your quick answer.
I have played with Inspects (Inspection Rules), I have found out that I am limited to 12 hrs as a MAX timeout.
So if I understand correctly, the only way I can configure a single TCP port with a timeout of 24hrs is to configure a MPF ( Modular Policy Framework)
Am I correct?
thanks again
Yes, you are correct.
to change timeouts for specific tcp ports you need MPF.
PK
