ICserver.log is HUGE
Answered Question
Jan 13th, 2010
Checking the disk usage on my LMS Windows host I see that this file consuming 37.8GB of space. What can I do to correct this? App level logging was set to Info for all apps in RME, so I changed it to "Warn" for ICServer hoping that would help. Then did a purge but the file seemed to get bigger by a few hundred MB in the meantime.
thanks!
Overall Rating: 5 (1 ratings)
js88888888 Thu, 01/14/2010 - 09:38
Thanks, this fixed it. I set it for 512MB but its at 0KB since yesterday. I guess this is OK.
ebezombes Mon, 06/06/2011 - 05:37
I have the same issue, I try logrot which has worked, ICserver.log is empty, but several minutes later it goes huge.
Does your ICserver.log become huge an other time ?
Thanks, Elisabeth
