Problem upgrading firmware in ASA EasyVPN remote
Jan 13th, 2010
I have a bunch of ASA5505's setup as EasyVPN remote clients connecting to an ASA5520 that I want to upgrade the firmware in and cannot figure out how to. I can telnet and run the ASDM to them but cannot unpgrade firmware via TFTP or browsing to local files from the ASDM. Anyone done this?
Thanks!
JF
janf Wed, 01/13/2010 - 18:26
Yeah I checked that link. And I've upgraded my headend 5520's many times via TFTP and local browsing of files. Problem is I am connecting to the EasyVPN remote via the inside interface (from the server side) and if I telnet to that device I cannot ping back to the host connecting from. I suspect this is the problem and don't know the resolution. If I am connected directly to the EasyVPN remote I can perform the upgrade. Of course this is impossible with the deployed devices. I need help from someone who has worked with this type of configuration. Heather, have you?
