Nexus 1000V Jumbo Frames MTU 9000
Jan 13th, 2010
I have an ESX host with 4 NICs and I added all four NICs to the 1000V DVS. All of the four NICs are part of a single port-profile (system-uplink). After I did that, everything works fine except the datastores are now not accessible. The datastores is a NFS mount which uses MTU 9000 and is mounting on a vlan. Before moving to 1000V DVS, the 4 NICs were configured with MTU 9000 in the standard vSwitch0. According to the Cisco config guide, MTU can't be set on vethernet interfaces. But the four NICs (eth3/3 - 3/6) are configured with system-uplink port-profile and MTU can't be set neither. The config guide is here http://www.cisco.com/en/US/docs/switches/datacenter/nexus1000/sw/4_0_4_s_v_1_2/interface/configuration/guide/n1000v_if_2basic.html#wp1221750
I'd like to know if anyone came across a similar situation. I'd hate to break the 4 NICs and move 1 or 2 NICs just to get it the MTU size correctly. I'm attaching part of the config for review. VLAN 142 is the storage vlan.
version 4.0(4)SV1(2)
vem 3
  host vmware id 35303738-3634-xxxxxxxxxxxxxxxxxxxx
vlan 1,142,221,223-224
vlan 101
  name control
vlan 102
  name packet
vlan 100
  name management
port-profile type vethernet Control
  vmware port-group
  switchport mode access
  switchport access vlan 101
  no shutdown
  state enabled
port-profile type vethernet Packet
  vmware port-group
  switchport access vlan 102
  no shutdown
  state enabled
port-profile type ethernet Unused_Or_Quarantine_Uplink
  description Port-group created for Nexus1000V internal usage. Do not use.
  vmware port-group
  shutdown
  state enabled
port-profile type vethernet Unused_Or_Quarantine_Veth
  vmware port-group
  shutdown
  state enabled
port-profile type vethernet data_vlan224
  vmware port-group
  switchport access vlan 224
  no shutdown
  state enabled
port-profile type ethernet data-uplink
  vmware port-group
  switchport mode trunk
  switchport trunk allowed vlan 142,221,223-224
  channel-group auto mode on sub-group cdp
  no shutdown
  state enabled
port-profile type vethernet data_vlan223
  vmware port-group
  switchport access vlan 223
  no shutdown
  state enabled
port-profile type vethernet service_console
  vmware port-group
  switchport access vlan 221
  no shutdown
  state enabled
port-profile type vethernet storage
  vmware port-group
  switchport access vlan 142
  no shutdown
  state enabled
port-profile type ethernet system-uplink
  vmware port-group
  switchport trunk allowed vlan 100-102,142,221,223-224
  no shutdown
  system vlan 100-102,142,221
  state enabled
interface port-channel1
  inherit port-profile system-uplink
interface port-channel2
interface Ethernet3/3
interface Ethernet3/4
interface Ethernet3/5
interface Ethernet3/6
interface Vethernet1
  inherit port-profile storage
  description VMware VMkernel, vmk1
  vmware dvport 160
interface Vethernet2
  inherit port-profile mgmt_network
  description VMware VMkernel, vmk0
  vmware dvport 352
jean-louis.auzepy Mon, 01/25/2010 - 05:05
Hello
did you try to set up the system MTU first?
Nexus1000v(config)# system jumbomtu 9000
Jlouis
felixjai Mon, 01/25/2010 - 07:30
Hi Jean-louis,
I believe we have resolved the issue. I found that the MTU setting needs to be set on the Port-channel instead of to the Ethernet interface.
I have another question. I have some Nexus 1000V instance that was installed for demo purpose, but I need to uninstall it from vCenter, but I keep getting error when object was still in used. I checked all hosts were removed and couldn't figure out what else needs to remove. Do you have a link for uninstalling? Thanks.
Felix Lai | Network & Security Architect | CCIE CCSP JNCIS-FWV JNCIA-SSL | Northeast | Presidio Networked Solutions
One Penn Plaza, Suite 1924, New York NY 10119 | [email protected]
D: 212.652.5717 | C: 917.805.1431 | F: 212.244.1685 www.presidio.com
jean-louis.auzepy Mon, 01/25/2010 - 07:39
Funny enough, i was trying to do exactly the same thing today.
After a lot of pain i managed to get rid of them using the troubleshooting guide:
You are logged in to the vSphere Client and the Nexus 1000V.
Step 1 From the vSphere Client, choose
Inventory
Networking
Step 2 Select the Nexus 1000V DVS and select the
Hosts
tab.
Step 3 Right-click each host, and choose
Remove from Distributed Virtual Switch.
Step 4 On the VSM, enter the
show vmware vc extension-key
command to verify the extension key.
Step 5 Delete the extension key that is present on vCenter Server using the Managed Object Browser (MOB) Unregister Extension API, as follows:
a. Go to the extension manager [https:///mob/?moid=ExtensionManager]
b. Click
[https:///mob/?moid=ExtensionManager&method=unregisterExtension]
c. Paste Cisco_Nexus_1000V_495736846 (your extension key attached to the DVS) and click
Invoke Method.
Step 6 From the Nexus 1000V Connection Configuration mode, remove the DVS from the vCenter Server as follows:.
n1000v# conf t
n1000v(config)# svs connection VC
n1000v(config-svs-conn)# no vmware dvs
If that doesn't help, may be you can post your error message
good luck
jlouis
felixjai Mon, 01/25/2010 - 07:44
thanks for the quick reply. What if the VSM is no longer there or was deleted before removing the SVS connection?
jean-louis.auzepy Mon, 01/25/2010 - 08:06
I might be wrong but i think your only way is to recreate a Nexus1K using the same extension key, register it again and unregister properly
I couldn't find any other way to remove it from the DVS. I m sure a lot of people will have the same problem and we should have the option on the next version(if we re lucky)
Sorry
Jlouis
ryan.lambert Mon, 04/19/2010 - 11:07
Just as a sidenote here (and a word of caution), there's currently an issue where the VEM modules will not retain the 9000 MTU setting upon reboot/restart, and will boot themselves @ 1500 MTU until they get their instructions from the VSM. This may cause some headaches for things like mounting network storage, etc... so just a variable to consider. In addition, it can be particularly ugly if your VSM storage is network-attached.
As I understand it, it is slated to be fixed in the next version of Nexus 1000v software later this month.
There are a lot of excellent posts out there regarding MTU, yet for weeks my colleagues and I continue to be confused about MTU on Nexus100v.
The confusions were around:
-How to set jumbo on N1kv
-Relationship between "system mtu" and "mtu"
-If "system mtu" is needed
-How to set "system mtu"
I wrote a short summary, based on multiple conversations with Cisco, and finally the definitive source. Hope it helps.
http://www.seanxwang.com/2010/07/nexus1000v-when-to-use-system-mtu.html
Related Content
