Change CallForwardAll for a line via Dial_InScript
Jan 13th, 2010
Hi.
Im Trying to create a script that will enable me to dial a number Where the following happends:
Step 1:
Please Enter the Directory number you would like to forward.
Step 2:
Please Enter PinCode for  Directory Number.
Step 3:
Tell Status : a) Directory Number : XXXX is currently not forwarded
                  b) Directory Number : XXXX is forwarded to 0 XX XX XX XX
Step 4:
Press 1 If you wish to remove CallForward | Press 2 if you wish to change CallForwardAll |  Press * to go Back. | To Exit, Disconnect the call.
Step 5:
Enter the Number you would like Forward your call to.
Step 6:
Tell Status and go back to Step 4
Id appreciate any help in regards to this.
Kindest Regards
Claus Pedersen
SAN J Fri, 01/15/2010 - 08:26
I don't know of any way to do this all within IPCCX scripting personally but maybe you can use a combination of IPCC scripting that triggers a batch script that launches the CCMUser URL and does the changes there??? Also, depending on what your end goal is, there might be a better way to handle this as opposed to call forwarding? As an example, if this is an operator phone, would time of day routing work better? Just a suggestion...if I'm even close to what you're trying to achieve....good luck.
flyingduckdk Thu, 01/28/2010 - 00:35
I was afraid you guys, would say something like that.
Has anyone created examples of such javaclasses and XML scripts?
I think i might get a better understanding of this if I can get to see it in work and fiddle with it.
I need to get from A-Z here... and im at B...
Kindest Regards
Claus Pedersen
Tanner Ezell Fri, 01/15/2010 - 10:01
  • Silver, 250 points or more
To Accomplish what you want you'd need to know two things:
     1. Java
     2. AXL
You'd need to create a custom Java class that your script could execute to accomplish what you want, short of that there is no good way to accomplish that.
flyingduckdk Thu, 02/11/2010 - 04:15
And good links for acomplishing just that ?
Im not your average java coder....
