FTP troubles
Jan 14th, 2010
Dear ALL,
I'm going to show to all of you a problem concerning file transfer that involves a Cisco PIX 515E 6.3 (4), an  ftp server (SERV-U) and a client side.
Client side is composed of an automatic procedure  (in order to download files) running on a Windowx XP and an ISA Server 2000.
Every 5 file transfer, at least 2 fail with this kind of error:
from ftp server side
Error sending file customer-file.txt, aborting (0 bytes/sec - 0 bytes, unable to open data connection)
and from PIX side
%PIX-6-303002:  Customer Public IP Retrieved FTP Server Public IP:customer-file.txt
%PIX-4-106023:  Deny tcp src inside:FTP Server Private IP/20 dst outside:Customer Public IP /4198 by access-group "acl-outbound"
.........................................but, there is not any acl-outbound denying that kind of traffic
Please, anyone of experienced that kind of trouble?
                                           Alberto Brivio
albertobrivio42 Fri, 01/15/2010 - 00:22
the ACE concerning the problem are:
access-list acl-inbound permit icmp any any                               first line
access-list acl-inbound permit tcp any host A.B.C.D eq ftp
access-list acl-inbound deny ip any any                                     last line
access-list acl-outbound permit icmp any any                             first line
access-list acl-outbound permit tcp 192.168.0.0 255.255.255.0 any eq ftp
access-list acl-outbound deny ip any any                                    last line
moreover there is the following line
fixup protocol ftp 21
Ganesh Hariharan Fri, 01/15/2010 - 01:12
Hi Alberto,
Following can be the reasons which has resulted the below issue in pix for ftp communication:-
eny protocol src [interface_name:source_address/source_port]
dst interface_name:dest_address/dest_port [type {string}, code {code}] by access_group
acl_ID
Explanation: An IP packet was denied by the ACL. This message displays even if
you do not have the log option enabled for an ACL.
Recommended Action: If messages persist from the same source address, messages
could indicate a foot printing or port scanning attempt. Contact the remote host
administrators.
FTP connection from src_ifc:src_ip/src_port to  dst_ifc:dst_ip/dst_port,
user username action file filename
Explanation: This event is generated whenever a client uploads or downloads a
file from the FTP  server. src_ifc The interface where the client resides. src_ip The
IP address of the client. src_port The client port. dst_ifc The interface where
the server resides. dst_ip The IP address of the FTP server. dst_port The server
port. username The FTP username. action The stored/retrieved actions. filename The
file stored or retrieved.
Recommended Action: None.
file from the FTP  server. src_ifcThe interface where the client resides. src_ipThe
Ganesh.H
albertobrivio42 Mon, 01/18/2010 - 07:56
I'm going to upgrade pix on next days.
Just for info for all people reading thread,  removing access-list controlling traffic from inside to outside, problem disappears.
        Alberto Brivio
