Understanding Node ID: on CUCM 7
cisco_admin1
Level 3
Level 3
hi there,
I have noticed the following in the applogs from RTMT from a CUCM (Pub) in the cluster
Remote Node ID:4 Remote Application ID:100
Whilst http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/err_msgs/7_x/ccmalarms701.html show what the application ID is, I still cannot work out what the remote node is.
The logs are very long, but here is a snapshot:
Oct 31 13:03:14, LDSCMPUB01, Error, Cisco CallManager, : 1531: Oct 31 13:03:14.238 UTC : %CCM_CALLMANAGER-CALLMANAGER-3-SDLLinkAppProtocol: SDL Link Connection Refused. Remote Application Link Protocol Version:7.1.2.20000-2 Local Application Link Protocol Version:7.1.2.21900-5 Remote Node ID:3 Remote Application ID:200 Remote Application Version: Cluster ID:StandAloneCluster Node ID:LDSCMPUB01, 1705
Oct 31 13:03:14, LDSCMPUB01, Error, Cisco CallManager, : 1532: Oct 31 13:03:14.288 UTC : %CCM_CALLMANAGER-CALLMANAGER-3-SDLLinkAppProtocol: SDL Link Connection Refused. Remote Application Link Protocol Version:7.1.2.20000-2 Local Application Link Protocol Version:7.1.2.21900-5 Remote Node ID:3 Remote Application ID:100 Remote Application Version:CUCM AppVersion=7.1.2.20000-2 Cluster ID:StandAloneCluster Node ID:LDSCMPUB01, 1706
Oct 31 13:03:24, LDSCMPUB01, Error, Cisco CallManager, : 1533: Oct 31 13:03:24.586 UTC : %CCM_CALLMANAGER-CALLMANAGER-3-SDLLinkAppProtocol: SDL Link Connection Refused. Remote Application Link Protocol Version:7.1.2.20000-2 Local Application Link Protocol Version:7.1.2.21900-5 Remote Node ID:4 Remote Application ID:200 Remote Application Version: Cluster ID:StandAloneCluster Node ID:LDSCMPUB01, 1707
any advice would be great,
3 Accepted Solutions
Jaime Valencia
Go to the CUCM server page, click on each server and you'll see the node id on top of the page
They get one as they're installed, PUB has 1, 1st SUB gets 2 and so on.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Yes, that's the one
java
java
6 Replies 6
Jaime Valencia
java
java
Many thanks to the very quick reply!!
i am assuming it is the
CTI ID   1
listed in the Cisco Unified CM Configuration page?
Yes, that's the one
java
java
Yes.
is it possible to get the CUCM cluster NodeId via SNMP?
Thanks, JM.
Node ID
From cli:
run sql select * from callmanager
