Blank Keystone Patch Panel
Jan 14th, 2010
We need some new patch panels at my company. I am thinking about going with blank keystone patch panels (ex. http://www.amazon.com/StarTech-BLANKPATCH24-24port-Blank-Keystone/dp/B00066HS44/ref=sr_1_2?ie=UTF8&s=electronics&qid=1263479274&sr=1-2).
The fact that they are modular and you can re-order your terminations fairly easily seems like a big plus. We have had a lot of additional drops through the years, and my current patch panel port terminations are not very contiguous.
Does anyone use these panels? Do the jacks stay securely inserted?
Ganesh Hariharan Thu, 01/14/2010 - 23:34
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
Genrally what ever the jack panel all depends on the cabling vendor how he do cabling in the backend of the jackpanel.check out the below links for jack panel which are used in data centers. hope that helps out your query !!
http://sewelldirect.com/Networking/RackShelvesPanelsHardware/PatchPanels
http://www.rackmountsolutions.net/
http://www.siemon.com/network-patchpanels.asp
Ganesh.H
kellyrudnick Thu, 01/21/2010 - 06:30
What I would like to know, is if anyone has used a blank patch panel in which you snap in keystone jacks. I like the idea because it makes moving the jacks around rather easy, but I wasn't sure how well the overall design works.
