MDS9124 PAK/LIC Installation
Janke2345
I was using the online Cisco license registration wizard to get a few licenses from the PAK's I recieved via mail but I made a mistake. When I went through the registration process it asks you for the Serial Number / Host ID. Well I looked at the unit itself and wrote down what I thought at the time was the serial number. Come to find out it's actually different. I tried to go through the registration process again and of course I was unable to. What do I need to do to get the PAK's unregistred so I can go through the process again or is their a way to edit the license file itself?
Galen Zhang
Use the show license host-id command to obtain the serial number for your switch. The host ID is also referred to as the switch serial number.
switch# show license host-id
License hostid: FOX064317SQ
2) Open a TAC SR, and requst Cisco license team to help you with the infomration you have (license type, host id)
