Trend IOS Content Filtering on 871, missing 'Trend' command?
Jan 14th, 2010
I've recently purchased an 871 with Trend IOS Content filtering license.  I'm running the latest 12.4.24T2 c870-advsecurityk9-mz.124-24.T2.bin and the paramater-map command;
parameter-map type trend-global global-param-map
doesn't work...there is no type 'trend-global'.  Can you please advise?  I've tried via the CCP gui and the option for web security is greyed out.  Thanks
Jason
Panos Kampanakis Fri, 01/15/2010 - 14:54
  • Cisco Employee,
Jason,
Advanced IP Services image is required on the 800 series.  On the 800 series there is also a "Universal" image that requires a specific software license to enable the feature. You can check this with the output of show license
You need to also have a separate license for this subscription based feature.
PK
