mihagan Fri, 01/15/2010 - 02:25
I may need more detail to accurately answer your question but I believe you are asking whether or not you can configure a specific DHCP pool for each VLAN and the answer is yes...but, it depends on the devices involved in your network.
Is there a specific device you are curious about or were you wanting to know if it is even possible in the first place?
tm4mulator Fri, 01/15/2010 - 05:20
Thanks for the reply. I will be working Cisco 2960 & 3560 switches. The 3560 will be the core switches and the 2960 will hang off it. I will also configure the 3560 switches with HSRP for redundancy. I would like to configure specific DHCP pool for the created VLAN's. Do you knows the commands for creating DHCP pool for VLAN's. I have the commands for creating DHCP pool but not for VLAN's. Thanks in advance.
alissitz Fri, 01/15/2010 - 17:27
  • Silver, 250 points or more
Hello and good evening,
You create a DHCP scope on a 3560 just like any other IOS DHCP configs ...here is a sample config:
interface vlan 1
ip add 1.1.1.1 255.255.255.0
interface vlan 2
ip address  2.2.2.1 255.255.255.0
ip dhcp excluded-address 1.1.1.1 1.1.1.10
ip dhcp excluded-address 2.2.2.1 2.2.2.10
ip dhcp pool vlan1
   network 1.1.1.0 255.255.255.0
   domain-name cisco.com
   dns-server 4.4.4.2 4.4.4.1
   default-router 1.1.1.1
   lease 3
ip dhcp pool vlan2
    network 2.2.2.0 255.255.255.0
    default-router 2.2.2.1
   lease 3
Here is the link for configuring IOS DHCP services:
http://www.cisco.com/en/US/docs/ios/ipaddr/configuration/guide/iad_dhcp_svr_cfg_ps6441_TSD_Products_Configuration_Guide_Chapter.html
Your proposed design is a good one, and you have obviously done your homework!  A nice design!
I would say however, that this community is really more for Cisco Small Business products and your question is in reference to a Cisco traditional products.  I believe you will have a better experience by posting your question in the Cisco NetPro forums located here: http://forums.cisco.com/eforum/servlet/NetProf?page=main
That forum has subject matter experts on Cisco traditional products that may be able to answer your question.
HTH,
Andrew Lee Lissitz
