UK PRI settings
apedder123
I don't suppose you can help me out with UK PRI (ISDN30) settings?
I've set it as an E1 ISDN30 Primary NET5. There is then an option for Bearer Capability that I can't find a standard setting for.
CD light comes on next to the PRI port, but incoming calls get a BT The number you have dialled is tempoararily unavailable message.
Any hints grately received.
Adam
5 Replies 5
Steven Smith
Level 7
Level 7
http://www.cisco.com/en/US/docs/ios/12_2/dial/configuration/guide/dafchant.html#wp1000940
Not a bad guide.  Have you tried isdn incoming-voice voice command?
I've gone through this guide.
I'm getting this in a debug isdn q921:
004193: ISDN Se0/3/0:15 Q921: User RX <- BAD FRAME(0x0E05EF)
004194: ISDN Se0/3/0:15 Q921: User RX <- BAD FRAME(0x0E21EF)
004195: ISDN Se0/3/0:15 Q921: User RX <- BAD FRAME(0x0E07EF)
004196: ISDN Se0/3/0:15 Q921: User RX <- BAD FRAME(0x0E21EF)
004197: ISDN Se0/3/0:15 Q921: User RX <- BAD FRAME(0x0E09EF)
004198: ISDN Se0/3/0:15 Q921: User RX <- BAD FRAME(0x0E21EF)
004199: ISDN Se0/3/0:15 Q921: User RX <- BAD FRAME(0x0E0BEF)
004200: ISDN Se0/3/0:15 Q921: User RX <- BAD FRAME(0x0E21EF)
004201: ISDN Se0/3/0:15 Q921: User RX <- BAD FRAME(0x0E0DEF)
004202: ISDN Se0/3/0:15 Q921: L2_EstablishDataLink: sending SABME
004203: ISDN Se0/3/0:15 Q921: User TX -> SABMEp sapi=0 tei=0
004204: ISDN Se0/3/0:15 Q921: User RX <- BAD FRAME(0x0E21EF)
004205: ISDN Se0/3/0:15 Q921: User RX <- BAD FRAME(0x0E0FEF)
004206: ISDN Se0/3/0:15 Q921: User RX <- BAD FRAME(0x0E21EF)
004207: ISDN Se0/3/0:15 Q921: User RX <- BAD FRAME(0x0E11EF)
004208: ISDN Se0/3/0:15 Q921: User RX <- BAD FRAME(0x0E21EF)
004209: ISDN Se0/3/0:15 Q921: User RX <- BAD FRAME(0x0E13EF)
(and loads more)
and show isdn status shows:
Global ISDN Switchtype = primary-net5
ISDN Serial0/3/0:15 interface
        dsl 0, interface ISDN Switchtype = primary-net5
    Layer 1 Status:
        DEACTIVATED
    Layer 2 Status:
        TEI = 0, Ces = 1, SAPI = 0, State = TEI_ASSIGNED
    Layer 3 Status:
        0 Active Layer 3 Call(s)
    Active dsl 0 CCBs = 0
    The Free Channel Mask:  0x00000000
    Number of L2 Discards = 0, L2 Session ID = 48
--More--
I'm finding contradictary advice as to whether TEI_ASSIGNED is good or bad. Any advice?
Adam
Try this under the Serial Interface (D channel):
isdn protocol emulate network Marcos
I think I may have identified an incompatability with the ISDN 30 line and the cisco kit, so I'll ask the question in a different way:
Is the UC520 compatible with a DASS signalled ISDN 30 line (i.e. not ETSI ISDN30e)?
Looks like I'll have to have the line converted, but if you can give me a yes/no answer it would help.
Adam
UC500 are not compatible with DASS. Need to get ISDN upgraded to ISDN30e. Had the exact same problem. Will be chargable from BT at £10 a channel (capped at £600). Make sure your telco doesnt rip you off ;)
http://www.openreach.co.uk/orpg/pricing/loadProductPriceDetails.do?data=2Sayf620g5prs80AHzhxur%2FuVhXjMR5hQz3DdrCHJqBVrWsgMC%2F4dy9qJJFTkna2
