Does 6509 support shaping or Hierarchical policymap anyhow?
Answered Question
Jan 14th, 2010
Hello All,
I have a ME customer that is directly connected to a 6509 w/ Version 12.2(33)SXH4. By using the following config, I am trying to:
1- Limit overall traffic at 10 mbps
2- Prioritize voip traffic w/ 2 mbps
3- Limit Netapp traffic at 3 mbps
4- Remaining traffic gets 5 mbps
But I get errors when I apply service-policy under a Gi interface. Does 6509 support shaping or Hierarchical policymap anyhow?
access-list 181 remark Define & permit customer traffic to VoIP
access-list 181 permit ip any 192.168.66.0 0.0.0.255
access-list 182 remark Define & permit customer traffic to Netapp
access-list 182 permit ip any 192.168.62.5 0.0.0.0
access-list 183 remark Define & permit customer traffic to Remaining
access-list 183 permit ip any any
class-map match-all VoIP_TRAFFIC
match access-group 181
class-map match-all Netapp_TRAFFIC
match access-group 182
class-map match-all Remaining_TRAFFIC
match access-group 183
policy-map VoIP_CLASSIFICATION
class VoIP_TRAFFIC
  priority 2000
class Netapp_TRAFFIC
  police cir 3000000 bc 375000 be 375000 conform-action transmit exceed-action drop
class Remaining_TRAFFIC
  bandwidth 5000
policy-map EGRESS_QUEUING
class class-default
  shape aver 10000
  service-policy VoIP_CLASSIFICATION
int Gi3/15
service-policy output EGRESS_QUEUING
65_01(config-if)#service-policy output EGRESS_QUEUING
Hierarchical policymap is not supported for this interface. Configuration failed!
shape average command is not supported for this interface. Configuration failed!
65_01#sh run interface g3/15
Building configuration...
Current configuration : 250 bytes
interface GigabitEthernet3/15
bandwidth 10000
ip vrf forwarding XXX
ip address 10.2.127.209 255.255.255.252
load-interval 30
speed 100
duplex full
end
Correct Answer by Jon Marshall about 7 years 1 month ago
ctaymez wrote:
Hello All,
class VoIP_TRAFFIC
  priority 2000
  bandwidth 5000
class class-default
  shape aver 10000
int Gi3/15
bandwidth 10000
load-interval 30
speed 100
duplex full
end
It depends on the module/interface you are using. It is only supported on some WAN interfaces as shaping is not generally available on Catalyst switches -
6500 Q&A
Catalyst switches have a completely different queueing system than routers so most of the MQC type configuration for queueing is not available -
6500 PFC QOS
Jon
Overall Rating: 5 (1 ratings)
Correct Answer
Jon Marshall Fri, 01/15/2010 - 02:47
ctaymez wrote:
Hello All,
class VoIP_TRAFFIC
  priority 2000
  bandwidth 5000
class class-default
  shape aver 10000
int Gi3/15
bandwidth 10000
load-interval 30
speed 100
duplex full
end
6500 Q&A
6500 PFC QOS
Jon
Jerry Ye Mon, 01/18/2010 - 09:42
Like Jon said, this type of configuration can only be done on the WAN line cards, like the FlexWAN and the SIP/SPA. None of the LAN line cards (WS-X6xxx) will support HQoS.
HTH,
jerry
