UCCX call monitor/recording with IP Communicator
Jan 15th, 2010
Hi All,
Is there a possibility to use call monitor/recording in CSD while the agent phone is IP communicator?
It has no problem with hard phone but when I switch agent phone to IP communicator it doesn't work.
vadimpunk Fri, 01/15/2010 - 01:45
We are using both (soft phones and ip phones)  everething works fine. Maybe theris something wrong with your configuration
safety2008 Fri, 01/15/2010 - 04:14
I have attached some Nic card in
fo. we monitor alot here both with hard and softphones...my experience seems to show its
more than NIC cards, it more of the PC hardware that makes this work.
if you have one working check, hw of pc and os..also there are a bunch o
f posts on this if you use search..good luck, its frustrating.
anubhati Tue, 10/19/2010 - 17:13
After checking the documents also make sure IP communicator is configured in the followng way
- Make sure on the agent PC - under Ip communicator - preference - network - Device name is set to use "Use network apapter to generate device name"
- Under the above setting Select the active NIC card of the work station ( this should match with VOIP monitor service in postinatll of the work station )
- On CUCM IP communicator configuration page make sure the device name is the one what is generated in the above step
Hope this helps
