Data Sheet of Ethernet Module for 7206VXR
Jan 15th, 2010
I have a 7206VXR Router which currently has two single Ethernet port modules. I want to add more Ethernet ports to the router & Im thinking of installing
"PA-4E----4-Port Ethernet 10BaseT Port Adapter" to it.
Problem is that I cannot find the DATA SHEET of this module & I dont want to order it before readig relevant documemtation. Also note the IOS im using is
version 12.2(10c).
Giuseppe Larosa Fri, 01/15/2010 - 05:49
Hello Saif,
if used to connect to a LAN switch I would suggest a PA FE instead and use of vlan subinterfaces.
I remember I've used PA 4E and PA 8E ten years ago on C7500 but if I'm not wrong they are limited to half duplex mode (perhaps the PA 8E)
>> Cisco 7500 supports full-duplex mode on PA-4E.
using a PA FE with subinterfaces is a more common choice.
Hope to help
Related Content
