C3750 - show Boot
Jan 15th, 2010
Which image will load on the Cisco 3750 switch.
Server-SW_A#show boot
BOOT path-list      : flash:c3750e-universalk9-mz.122-44.SE.bin
Config file         : flash:/config.text
Private Config file : flash:/private-config.text
Enable Break        : no
Manual Boot         : no
HELPER path-list    :
Auto upgrade        : yes
Auto upgrade path   :
Timeout for Config
          Download:    0 seconds
Config Download
       via DHCP:       disabled (next boot: disabled)
Switch 1
BOOT path-list      : flash:c3750e-universal-mz.122-44.SE1.bin
Enable Break        : no
Manual Boot         : no
HELPER path-list    :
Auto upgrade        : no
Auto upgrade path   :
Server-SW_A#
Ganesh Hariharan Sat, 01/16/2010 - 04:43
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
The following output shows  Cisco 3750 switch stack comprised of two switches if yes then both switches show they are booting from flash:
If you want to change the path use the following command in switches
switch(config)#boot system switch all flash:c3750-ipbasek9-mz.122-37.SE.bin
Hope that helps out your query !!
If helpful do rate the valuable post.
Ganesh.H
Leo Laohoo Sun, 01/17/2010 - 13:34
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
12.2(44)SE1
