01-15-2010 06:18 AM - edited 03-06-2019 09:18 AM
I am new to setting up etherchannels and have a couple of questions.
I will be setting up on a Cisco 4506 to a Cisco 3750. I want to set up the etherchannel using ports 3/4 and 3/10 on the 4506 and use ports 1/0/1 and 1/0/10 on the 3750. It will only be using on vlan 1. I understand the commands that I need to use to set up but guess I do not understand the steps.
Do I need to administatively shut down the ports before I configure the switches. I will be using the channel-group 1 mode desirable command to set up layer two etherchannels. Do I need to configue on both switches with the ports administratively down and the use the no shutdown on these ports after the switch is configured ?
01-15-2010 06:33 AM
Hello Stephen,
Please refer to this document for step-by-step config guide on how to configure etherchannel
Reza
01-15-2010 06:41 AM
HI ,
Check out below link for etherchannel configuration hope that helps out query !!
http://www.cisco.com/en/US/tech/tk389/tk213/technologies_configuration_example09186a0080094647.shtml
Ganesh.H
01-16-2010 08:00 AM
First you configure the port channel 1
do admin shut the port channel 1
then you configure the ports and do admin shut the ports
then connect the cables to the ports and no shut the ports now the physical link will come up
finally do no shut for port channel 1
now check the port channel members using command show interface port-channel 1
regards
krishna
