Cross Stack Etherchannel
Jan 15th, 2010
Can you configure a cross stack etherchannel group between 2 gig ports on a 3750 stack, where one of the SFP's is LX & the other is SX?
Has anyone tried this?
Cheers
Colin
Jon Marshall Fri, 01/15/2010 - 08:23
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Cheers
Colin
Colin
Etherchannel does not care about the actual media so it should work fine. For example i have configured standard etherchannel using a combination of copper and fiber ports with no problems. As long as speed/duplex etc. are the same then it should work.
Jon
krishnakumarr Fri, 01/15/2010 - 08:47
hi
If you are using one end SX connector other end also should  be SX connector
You can use either copper or fiber media for ether channal or both mixed but physical link should be up
for that we need to use same type of connectors
SX wave lenth is different and LX wave lenth is different this will not communicate each other.
regards
krishna
Jon Marshall Fri, 01/15/2010 - 09:59
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Cheers
Colin
Colin
Krishna has read the question differently from me and either of us could be right. I read it that you had an SX connection (from another switch) and an LX connection from an other switch and i can't see an issue of bundling these together.
I think Krishna read it that you had multiple links with SX at one end and LX at the other. I agree with his answer for that case.
Jon
krishnakumarr Sat, 01/16/2010 - 00:50
Jon
I also agreed your point , we can do bundle either SX or LX,  the media the physical link should be up, my point is we cannot mix the media for establish physical connectivity.
Hope I answered correctly
Colin : have you tried the Ether channel bundles
regards
krishna kumar
c.walsh Thu, 01/21/2010 - 05:45
The toplogoy is....
2 x 3750 switches in a stack at both ends.
2 x LES circuits between the 2 sites.
Site A has one LES connected with SX multimode fibre & one LES connected with LX singlemode fibre.
Site B is configured the same way
We have configured a cross stack etherchannel at each end consisting of 2 x 1 gig LES circuits (1 is LX at both ends & the other is SX at both ends).
This solution works fine.
Leo Laohoo Sun, 01/17/2010 - 13:36
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
    2017 LAN, Wireless
As long as it goes to the same host/client.
