ASA 8.0.4 Phone Proxy - media-termination address NAT?
Jan 15th, 2010
On ASA 8.0.4 using the Phone Proxy feature, can the media-termination address be NAT'd on the inside?  If so how?  The address does not exist on any interfaces so that is why I ask.
-C
c3max Fri, 01/15/2010 - 11:59
From reading the documentation for ASA 8.2, it sounds like I need to upgrade.
ASA 8.2 gives the option to create one MTA instance with an IP on multiple interfaces.  This should solve my problem.
-C
Kureli Sankar Sat, 01/16/2010 - 19:44
Chase?
Yes, that is correct. I hope you have the link.
You can see sample config here. You not longer need a route on the inside router to come this ASA's inside interface for the MTA address.
https://supportforums.cisco.com/docs/DOC-8165#StepbyStep_configuration_example_
Per-Interface-MTA: (New feature in 8.2)
PhoneProxyASA(config)# media-termination mymta
PhoneProxyASA(config-media-termination)# address 14.36.107.91 interface outside
PhoneProxyASA(config-media-termination)# address 172.18.124.220 interface inside
-KS
Related Content
