Help on win7,dmz and radius server
Answered Question
Jan 15th, 2010
Helo
1.
Im jusing my SA540, on my Win7 64bit. Il really cant seem to get the SSL vpn to work.
2.
What is most proper when dealing with the radius server, put it in DMZ or LAN? Beside is there some real configuration site/help, on this?
Correct Answer by Steven Smith about 7 years 4 months ago
Windows 7 SSLVPN on the SA540 isn't supported yet, but should be supported soon.
I would setup the Radius server on the LAN.  Steps to set it up.
Administration -> Radius Server (give IP, port, secret)
Administration -> Domain (add domain, select auth type to be the radius type you want)
Let me know if you need more information.
Overall Rating: 5 (1 ratings)
Correct Answer
Steven Smith Fri, 01/15/2010 - 13:26
  • Gold, 750 points or more
flyfantomet1337 Fri, 04/02/2010 - 15:06
Ty got the radius nicely working, but still no sign of Win7 support on ssl?
Care to fill me in on a ETA?
Steven Smith Mon, 04/05/2010 - 07:22
Mid April will have the Windows 7 SSL support.
