UCCX 7.0 Get Reporting Statistic - Logged in Resources = -1
Jan 15th, 2010
I am running a check in a script to verify Logged in Resources from the CSQ:
Get Reporting Statistic:
Report Object: CSQ IPCC Express
Field: Logged-In Resources
Row ID: CSQ
Result Statistic: loggedInResources (int variable type)
IF Logged-In Resources < 1 THEN redirect to VM
I am also grabbing Not Ready Resources into a notReadyResources (int variable type) and doing the following IF:
IF notReadyResources == loggedInResources THEN redirect to vm.
While testing, debugging showed that when one agent was "talking", the loggedInResources variable showed a "-1" in lieu of a "1".  I have seen other posts where this occurs, but no resolutions.
Suggestions?
Thanks!
Tanner Ezell Fri, 01/15/2010 - 10:40
  • Silver, 250 points or more
r.stockton,
-1 is returned when the CSQ specified Does not exist.
