01-15-2010 11:32 AM - edited 03-04-2019 07:13 AM
I have very little idea about QoS.. can any1 help me on configuring QoS with below details.
I need to setup L3 QoS for voice with highest priority and rest all traffic with best possible..
I have to configure the L2 QoS also for voice traffic as highest priority.
can some 1 help by sharing the right doc or config example.
Thanks & Regards
Amardeep
01-15-2010 11:46 AM
Thanks & Regards
Amardeep
Amardeep
There are a lot of example on Cisco's site that we could point you to but first we need to know what devices you are configuring this on ie. which routers and which switches. Note that there is quite a lot of difference in QOS capabilities between switch models so please specify exaclty which switch models you are using.
Jon
01-16-2010 10:06 AM
Hi all,
I need to configure WAN QoS mostly on 6506 sup 720/ sup 32 and some places 3750 switches which connect with our other site through metro ethernet link.
Requirment is Voice, Video confrencing and time sensetive traffic should be prioritised and rest all should be on best effort.
I have configured below QoS configuration for WAN QoS in both the end, but not sure how effective it will be.Need suggestion
Also what will be inobund configuration setting.
class-map match-any voice-traffic
match ip rtp 16384 16383
match ip dscp ef
match ip dscp cs5
match ip precedence 5
class-map match-any voice-signalling
match access-group 170
match ip rtp 2048 1281
policy-map voice-qos
class voice-traffic
priority percent 10
class voice-signalling
bandwidth percent 5
class class-default
fair-queue
Interface X/X
Service-policy-map Voice-qos out
Thanks & Regards:
Amar
