Site-to-Site VPN between Cisco ASA 5505 and Sonicwall TZ170
Answered Question
Jan 15th, 2010
I'm trying to set up a site-to-site VPN between our datacenter and office.  The datacenter has a Cisco ASA 5505 and the office has a Sonicwall TZ170.  I have managed to configure both so that the vpn connects.  From each of the firewalls I can ping the internet firewall IP on the other side and from an office computer I can ping the internal datacenter firewall IP but I cannot route traffic between the datacenter and office private subnets.  Can anyone help?
The below config has had IPs/passwords changed.
Datacenter External: 1.1.1.4
Office External: 1.1.1.1
Datacenter Internal: 10.5.0.1/24
Office Internal: 10.10.0.1/24
: Saved
ASA Version 8.2(1)
hostname datacenterfirewall
domain-name mydomain.tld
enable password <removed> encrypted
passwd <removed> encrypted
names
name 10.10.0.0 OfficeNetwork
name 10.5.0.0 DatacenterNetwork
interface Vlan1
nameif inside
security-level 100
ip address 10.5.0.1 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address 1.1.1.4 255.255.255.0
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
ftp mode passive
clock timezone EST -5
clock summer-time EDT recurring
dns server-group DefaultDNS
domain-name buydomains.com
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
access-list inside_access_in extended permit icmp any any
access-list inside_access_in extended permit tcp any any
access-list inside_access_in extended permit udp any any
access-list inside_access_in extended permit ip any any
access-list outside_access_in extended permit icmp any any
access-list outside_access_in extended permit udp any any eq isakmp
access-list pixtosw extended permit ip DatacenterNetwork 255.255.255.0 OfficeNetwork 255.255.255.0
access-list pixtosw extended permit icmp DatacenterNetwork 255.255.255.0 OfficeNetwork 255.255.255.0
access-list pixtosw extended permit ip OfficeNetwork 255.255.255.0 DatacenterNetwork 255.255.255.0
access-list pixtosw extended permit icmp OfficeNetwork 255.255.255.0 DatacenterNetwork 255.255.255.0
access-list outside_cryptomap_66.1 extended permit ip any OfficeNetwork 255.255.255.0
access-list outside_cryptomap_66.1 extended permit ip OfficeNetwork 255.255.255.0 any
access-list outside_cryptomap_66.1 extended permit icmp any OfficeNetwork 255.255.255.0
access-list outside_cryptomap_66.1 extended permit icmp OfficeNetwork 255.255.255.0 any
pager lines 24
logging enable
logging asdm informational
mtu inside 1500
mtu outside 1500
ip verify reverse-path interface outside
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-623.bin
no asdm history enable
arp timeout 14400
nat-control
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0
access-group inside_access_in in interface inside
access-group outside_access_in in interface outside
route inside 0.0.0.0 0.0.0.0 1.1.1.1 1
route outside OfficeNetwork 255.255.255.0 1.1.1.1 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
http server enable
http 10.5.0.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec transform-set walthamoffice esp-aes-256 esp-sha-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto dynamic-map ciscopix 1 match address outside_cryptomap_66.1
crypto dynamic-map ciscopix 1 set transform-set walthamoffice
crypto dynamic-map ciscopix 1 set reverse-route
crypto map dynmaptosw 66 ipsec-isakmp dynamic ciscopix
crypto map dynmaptosw interface outside
crypto isakmp identity address
crypto isakmp enable outside
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
crypto isakmp policy 13
encryption aes-256
hash sha
group 2
lifetime 28800
crypto isakmp policy 30
encryption aes-256
hash sha
group 2
lifetime 86400
no crypto isakmp nat-traversal
telnet 10.5.0.0 255.255.255.0 inside
telnet timeout 5
ssh 10.5.0.0 255.255.255.0 inside
ssh timeout 5
console timeout 0
management-access inside
dhcpd address 10.5.0.2-10.5.0.254 inside
dhcpd enable inside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
ntp server 66.250.45.2 source outside
ntp server 72.18.205.157 source outside
ntp server 208.53.158.34 source outside
webvpn
group-policy DfltGrpPolicy attributes
vpn-idle-timeout none
username admin password <removed> encrypted
tunnel-group 1.1.1.1 type ipsec-l2l
tunnel-group 1.1.1.1 ipsec-attributes
pre-shared-key *
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum 512
prompt hostname context
Cryptochecksum:7f319172e5de9c0e550804a263f8e49e
: end
Correct Answer by JORGE RODRIGUEZ about 7 years 5 months ago
Mattew, one obious statement missing  is the  nat exempt rule for your tunnel..  your access list pixtosw is similar on this example I assume you have gone through this link, if not review configs at both sides.
add the nonat rule statement in asa  and try again.
nat (inside) 0 access-list pixtosw
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a008052c9d4.shtml
Overall Rating: 5 (1 ratings)
Correct Answer
JORGE RODRIGUEZ Fri, 01/15/2010 - 18:03
  • Green, 3000 points or more
matthewshields Thu, 01/21/2010 - 09:35
Sorry for the delay in response.  This was the fix, it looks like when I originally configured the ASA there was an error adding that nat rule and it didn't take.  I was able to figure out what the issue was and re-add that nat command and it works successfully.
thank you
-matt
Related Content
