01-15-2010 01:11 PM - edited 03-04-2019 07:13 AM
Hi ,
Is there a way for route leaking in the MPLS CE?
CE1 has Global routing & a VRF named VRF_A. Is it possible to that a single host in Global routing can communicate with VRF_A host or vice a versa?
Santosh
Solved! Go to Solution.
01-15-2010 03:06 PM
The gateway will be the device to take the route into GRT, so this IP must be in GRT not VRF_A.
The 'global' keyword is the key here.
01-15-2010 01:59 PM
You can use static routing.
ip route vrf VRF_A x.x.x.x x.x.x.x.x [gateway ip] global
this leak routes into VRF
then
ip route x.x.x.x x.x.x.x [interface under vrf]
this leak routes into GRT.
Edison.
01-15-2010 02:05 PM
Hi Edison,
Thanks for the reply. What should be the Gateway IP. I think the Gateway should be rechable under both VRF and Global routing ?
Santosh
01-15-2010 03:06 PM
