UC520-IP Communicator with SSL VPN
Jan 15th, 2010
When connected with the Cisco Anyconnect client the IP Communicator will start and register with system correctly. However, I'm not able to make calls with it (don’t get a dial tone) and every 3 minutes or so all the softkeys will disappear and then it will say registering and the softkeys will reload. However, still cannot make a call.
The IP Communicator will work fine on the same computer using the IPSEC vpn client.
Any ideas?
Steven Smith Tue, 01/19/2010 - 08:14
  • Gold, 750 points or more
What version of IOS are you running?  What version of IP Communicator are you running?  This might be a bug with the SSL VPN, but hard to know without version information.
tazpb2000 Mon, 02/15/2010 - 19:22
IOS version: Version 12.4(22)YB4
IP Communicator version 7.0.3.0 running on XP SP3 Pro.
Let me know if you need additional information.
Thanks for your help!
Steven Smith Tue, 02/16/2010 - 07:57
What version of anyconnect are you using?
tazpb2000 Tue, 02/16/2010 - 18:53
AnyConnect Version 2.3.2016. I have not upgraded to the latest version because I'm using a self signed cert for testing which I believe will cause problems with the newer version?
All the other programs I've tested work fine over the AnyConnect client (Exchange, RDP, internal websites, file shares, etc).
Jeremy
Steven Smith Wed, 02/17/2010 - 09:46
Would you mind opening a case for this?  I am familiar with one bug on this, but it is fixed on your release (CSCsv64889).
This is probably going to be a bit to difficult to do over the community.
