Cisco IOS Image 12.2(25)EZ for etherswitch module for 2821 router
Answered Question
Jan 15th, 2010
Dear Netpros,
I am searching the cisco site to download this image for the 2821 router to resolve the IPT POE issue but I can not find anywhere in the site.
I did login using CCO ID provided. The etherswitch NM pre-requisites shows that we have to use this 12.2(25)EZ image for the switch module to provide POE to the IP Phones.
Arumugam.
Correct Answer by krishnakumarr about 7 years 5 months ago
Can you provide me the part number for ether switch module and current show ver on 2821 router
regards
krishna
Overall Rating: 5 (1 ratings)
Correct Answer
krishnakumarr Sat, 01/16/2010 - 03:57
regards
krishna
arumugasamy Sat, 01/16/2010 - 12:09
Kumar,
The part of the module is
NME-X-23ES-1G-P
I attached the sh ver of Host Router as below and also at the end attached the sh ver for the etherswitch module.
------------------ show version ------------------
Cisco IOS Software, 2800 Software (C2800NM-ADVENTERPRISEK9-M), Version 12.4(22)YB4, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Fri 07-Aug-09 14:42 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
R1BAHRAINz uptime is 3 days, 20 hours, 35 minutes
System image file is "flash:c2800nm-adventerprisek9-mz.124-22.YB4.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
Cisco 2821 (revision 53.51) with 243712K/18432K bytes of memory.
Processor board ID FHK1249F1ZY
3 Gigabit Ethernet interfaces
1 terminal line
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
62720K bytes of ATA CompactFlash (Read/Write)
The below attached is the sh ver of Etherswitch module
Cisco IOS Software, C3750 Software (C3750-IPBASE-M), Version 12.2(25)SEE2, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Fri 28-Jul-06 08:46 by yenanh
Image text-base: 0x00003000, data-base: 0x00EE3E54
ROM: Bootstrap program is C3750 boot loader
BOOTLDR: C3750 Boot Loader (C3750-HBOOT-M) Version 12.2(25r)EZ, RELEASE SOFTWARE (fc1)
S1BAHRAINz uptime is 1 day, 23 hours, 22 minutes
System restarted at 18:34:20 UTC Thu Apr 20 1905
System image file is "flash:c3750-ipbase-mz.122-25.SEE2/c3750-ipbase-mz.122-25.SEE2.bin"
cisco NME-X-23ES-1G-P (PowerPC405) processor (revision 3.0) with 118784K/12280K bytes of memory.
Processor board ID FOC11131CZ5
Last reset from power-on
1 Virtual Ethernet interface
23 FastEthernet interfaces
2 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : 00:1B:54:BB:15:00
Motherboard serial number       : FOC11131CZ5
Model revision number           : 3.0
System serial number            : FOC11131CZ5
Top Assembly Part Number        : 800-25011-01
Top Assembly Revision Number    : N/A
Version ID                      : V01
Hardware Board Revision Number  : 0x00
Switch   Ports  Model              SW Version              SW Image
*    1   25     NME-X-23ES-1G-P    12.2(25)SEE2            C3750-IPBASE-M
