MPLS Multiple TE tunnel
Answered Question
Jan 16th, 2010
Hello Guys , I have a basic question from MPLS TE
I have 2 PE router and 2 TE tunnels between them . I have 2 different customers connected to the PE's . I want Customer 1 traffic need to take the path Tunnel 1 and Customer 2 traffic through Tunnel 2. Could anyone help me to understand, how we will configure  that and in what basis it selects the path
Thanks in advance
Harish
Correct Answer by amit.bhagat about 7 years 5 months ago
Hi Harish,
What you want to achieve is "Per-VRF MPLS-TE tunnels". In this case, each VRF customer traffic can be passed through different MPLS-TE tunnel. You will find all the necessary config and explaination on the following link-
http://sites.google.com/site/amitsciscozone/home/important-tips/traffic-engineering/per-vrf-mpls-te-tunnels
HTH.
Amit.
Overall Rating: 5 (1 ratings)
Correct Answer
amit.bhagat Sun, 01/17/2010 - 01:01
Hi Harish,
HTH.
Amit.
harish.ab Sun, 01/17/2010 - 01:15
Hello Amit
Thank you very much. This is what I wanted.
Harish
