DNS Issue with AnyConnect SSL VPN
Jan 16th, 2010
I implemented Anyconnect ssl vpn on my network and it working fine, after the connection was established and got an ip address from the pool, RDP is working by entering IP address of the machine (172..25.1.18), but accessing the machine by it is qulified name it fails (xxxx.agfund.net), I am able to bing the machine IP address not machine name. Below is part of my configuration:
dns domain-lookup inside
dns server-group DefaultDNS
name-server 172.30.100.200
domain-name lookup
access-list Inside_SP_3 standard permit 172.0.0.0 255.0.0.0
access-list nonat_3 extended permit ip 172.0.0.0 255.0.0.0 192.168.20.0 255.255.255.0
global (DMZ) 1 interface
nat (inside) 0 access-list nonat_3
nat (inside) 1 0.0.0.0 0.0.0.0
nat (DMZ) 0 access-list nonat_3
group-policy GroupPolicy3 internal
group-policy GroupPolicy3 attributes
dns-server value 172.30.100.200
vpn-tunnel-protocol svc
split-tunnel-network-list value Inside_SP_3
default-domain value agfund.net
webvpn
  svc keep-installer installed
  svc ask none default svc
tunnel-group TunnelGroup3 type remote-access
tunnel-group TunnelGroup3 general-attributes
address-pool Third_Pool
default-group-policy GroupPolicy3
tunnel-group TunnelGroup3 webvpn-attributes
group-alias ssgroup_user3 enable
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect netbios
  inspect rsh
  inspect rtsp
  inspect skinny
  inspect esmtp
  inspect sqlnet
  inspect sunrpc
  inspect tftp
  inspect sip
  inspect xdmcp
  inspect http
  inspect pptp
Trending Topics - Security & Network
