CM 4.1(3) DCD copy/export
Jan 16th, 2010
Is it possible (an old thread implied it is to either copy/export the DC Directory from one cluster to another (new/identical one).
I'd like to if possible:
1) Copy all user db across from DCD
2) Or copy the fast dials/PAB entries
3) And copy Attendant Console Speedial entries
So ideally I'd like to copy the whole DCD to a new server being built with identical parameters.
The Publisher is defunct, there is no backup (not my doing!), but we have subscribers running.
I know its not possible to extract the whole SQL DB for a Subscriber and rebuild on a new Publisher (well its probably possible for an expert SQLer). But if I could at least get the users back with their old PINs/Passwords/FastDials-PAB/AC Speed dials, that would be a major help.
The problem is I haven't figured out how to use the "DC Directory Bulk Export", and can't find any example instructions.
