cisco series 2811 router
Peter Paluch Sun, 01/17/2010 - 08:15
  • Cisco Employee,
I was not able to dig up any particularly useful information about your problem. What I suggest, though, is:
  • reformatting your CF card using the command format flash: in the privileged EXEC mode and downloading the IOS back as the first file to be placed on the CF card
  • upgrading to the latest stable IOS version if possible
  • possibly upgrading the ROMMON code if previous steps fail
Best regards,
Peter
krishnakumarr Sun, 01/17/2010 - 21:21
pl find the workaround for your prob
CSCse99958
Symptoms: A Cisco router may fail to access a flash card after formatting it, and the following error message is generated:
*** Emulating mis-aligned load at 0x80000190
PC = 0x8001179c ... succeeded
Conditions: The symptom is observed on a Cisco 7200 series, Cisco 7301, and Cisco 7500 series that run Cisco IOS Release 12.4(10) or Release 12.4(12) and occurs only when a flash card is accessed from the ROMmon prompt.
Workaround: There is no workaround. Note that the symptom does not occur in Release 12.4(8a) or an earlier release.
regards
krishna kumar
Ganesh Hariharan Sun, 01/17/2010 - 22:00
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
As your series is 2811 try to do the following things it can be due to faulty flash orimage.Reflashing it appeared not to be issue.
This type of error genrally seen in cisco 7206 series routersA Cisco router may fail to access a flash card after formatting it, and the following error message is generated:
*** Emulating mis-aligned load at 0x80000190 PC = 0x8001179c ... succeeded
check out the below link for brief description of the error hope that helps out your query !!
http://www-china.cisco.com/en/US/docs/ios/12_4/release/notes/124MCAVS.html
If helpful do rate the post.
Ganesh.H
Itzcoatl Espinosa Tue, 01/19/2010 - 06:55
  • Cisco Employee,
  • Events Top Contributors,
    2013
As suggested before formatting the flash could help solving the issue, if not, I strongly suggest to replace the flash card. I have seen a couple of cases where the RMA solved the problem
thanks,
Itzcoatl
