01-17-2010 01:07 PM - edited 07-03-2021 06:25 PM
I have a Cisco ACS version 4.0 and a Wireless Network with a Wireless Lan Controller 4402 version 5.2. The actual WLAN is protected whit WPA but I like to use the local ACS database for user authentication in the wireless network. Is this possible ?
Regards.
01-18-2010 11:10 AM
Yes, wlan can authenticate using AAA servers.
This link explaning the configuration for you.http://www.ciscosystems.lt/en/US/tech/tk722/tk809/technologies_configuration_example09186a0080665d18.shtml01-18-2010 11:19 AM
and you can also extend that to your lobby admins of the WLC if you have guest SSIDs.
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a0080871921.shtml
02-07-2010 06:18 PM
Thanks for the answers.
With the WLAN network configured with ACS authentication (local user database), I can add a second authentication using Microsoft Certification downloaded from Microsoft certification authority server?
First step of the authentication: Local Database from the ACS
Second step of the Authentication: Microsoft Certificate
This is possible?
thanks
