Configuration and Implementation steps in Low Level Design
Jan 17th, 2010
Hi All,
i just want to ask why we should put the implementation steps and some of configurations portions of proposed technical design in Low Level Design document. as long as the people in the site are Technical then no need to add such information and just give them the Config. file of the device (show run) at the end of the project. and just we state that the solution will be by specific technology without how (e.g: will deploy BGP).
i see that in LLD of Cisco that they give the solution implementation steps with config. portion.
can anyone give me a rigid justification why we need to include such information in LLD.
mimeyer Tue, 01/19/2010 - 12:50
Hi, Mahmoud --
Without seeing the document or documents in question, it is difficult to determine whether the level of detail is appropriate or perhaps unnecessary. Could you please provide links to examples that you have in mind?
Michael
