01-17-2010 11:00 PM
hi,
How can login to tacacs configured devices through CNA.
I tried HTTP authentication it diesnt work
plss help
01-18-2010 09:34 AM
You need to use : ip http authentication tacacs, as CNA communicates with the switch over HTTP.
Make sure to remove Ip http authentication local
01-18-2010 08:45 PM
hi,
thanks, I managed to login but now real issue is its showing unsupported device.
Switch Ports Model SW Version SW Image
* 1 26 WS-C3750-24TS 12.2(25)SEE3 C3750-IPSERVICESK9-M
2 52 WS-C3750-48TS 12.2(25)SEE3 C3750-IPSERVICESK9-M
thanks
01-18-2010 08:46 PM
What version is your CNA? CNA version 5.0 supports WS-C3750-24TS.
01-18-2010 08:56 PM
hi,
thanks, CNA 5.5...I managed to login now the issue is showing unsupported device.
01-21-2010 05:47 AM
I'm seeing this same issue. Local authentication works fine but as soon as aaa is enabled the device is 'unsupported' by cna. I believe it is possibly related to the switch ios version, 12.2(25) as it is working on slightly newer revisions, 12.2(46) for example, on other switches but I'm not able to upgrade anytime soon to test.
