which AC power-cable type is used in India and the Philippines?
Answered Question
Jan 17th, 2010
hi all,
I plan to install the cat6500 with 3000watt AC-power supply in India and the Philippines.
but i can't know the exact power cable type to install.
who's knows about this??
which type i should use to install respectively.
Correct Answer by Ganesh Hariharan about 7 years 4 months ago
Genrally depends on how the power socket will be in which you are going to connect the power cord of cisco 6513,we have deployed in our Data center is the CAB-ACS-16= (Switzerland) depends on the power conencteor in tha rack.
http://www.cisco.com/en/US/products/hw/switches/ps700/products_tech_note09186a00800a7af7.shtml#cat6k1
Hope that clear out your query!!
Ganesh.H
Check out the below link power cord specification for different types of power sepcicification hope that helps out your query!!
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/hardware/Chassis_Installation/Cat6500/0apwsply.html#wp1029024
If helpful do rate the valauble post.
Ganesh.H
Overall Rating: 5 (2 ratings)
Correct Answer
Ganesh Hariharan Sun, 01/17/2010 - 23:20
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
Ganesh.H
Sanghee Han Sun, 01/17/2010 - 23:34
thanks for your answer
but i can find the cable type for India or the Phillippines in the document you suggest.
Correct Answer
Ganesh Hariharan Mon, 01/18/2010 - 00:08
Ganesh.H
Sanghee Han Mon, 01/18/2010 - 21:17
thanks for your answer.
it's very helpful, thanks again.
