Safenet Softremote VPN Client 10.8.3 with Pix 6.3(5)
Jan 17th, 2010
Dear All,
I am using the VPN software in object, for the first time.
I have just configured the vpn tunnel and the phase I And Phase II are ok.
So the tunnel go up, but the SafenetVPN client do not create the virtual adapter!!!!
I think that the problem is due by the pix config, the Cisco command reference guide 6.3 tells about vpngroup command:
"Supports Cisco VPN Client Version 3.x (Cisco Unified VPN Client Framework) and Easy VPN Remote
Infact to exchange the isakmp key I have used :
isakmp key ******** address netmask no-xauth
instead of the vpdngroup command.
My question is, there is a way to configure the ip local pool and the wins and dns setting for the other VPN Clients?
Best regards,
