Internet gateway for a site to site VPN branch office
Jan 18th, 2010
My main office A has 2811 as internet and VPN gateway while I have branch office B as remote site with ASA5505. They built a VPN between these two offices and worked well. Can I put force the internet traffic from office B to office A and then goto internet with office A 2811?
Yes - one solution
1) A Dynamic routing protocol
2) A GRE tunnel (to encapsulation dynamic routing)
3) Specific static routes for tunnel end points
4) Specific NAT
Once you have the above from site to site, you can inject a default route into the routing protocol, and the routers will take care of the rest.
Or you can try and use DMVPN and static routes.
HTH>
