claer arp-cache
Jan 18th, 2010
i have  DSL link   in different sites   .i m having a problem with that
suddenly the link goes down in my two branches as i restart my DSL modem or
give clear arp-cache  command on my router  the link  goes up .i have also
give static arp entry on my Two routerThis problem i m having in my TWO sites remaining  2 sites are  running  fine
.where i m getting wrong & what will be the solution to resolve this hectic
problem .
Actually im doing uneuqal Cost load balancing these DL links are  used  for secondary
i have 3 Dxx p2p frm my HO to branches
Thanks in advance
Giuseppe Larosa Mon, 01/18/2010 - 06:27
  • Hall of Fame,
    Founding Member
Hello Faizan,
without more details it is difficult to say something.
Are you using EIGRP or static routing?
if using static routing have you defined an ip address as next-hop for default route (recommended) or you specify the outgoing interface (not recommended relies on proxy ARP and increases ARP activity on router)?
post interesting parts of configuration, mask public ip addresses and remove username / passwords
Hope to help
Giuseppe
