Need to create TCL script to send syslog message when difference in rxload on 2 serial interfaces is greater than a certain amount for 10 minutes
Jan 18th, 2010
I need to create a TCL script to check when the difference in the absolute value of the rxload on two interfaces, serial0/0/0:0 and serial0/0/1:0 is greater than 20 for more than 10 minutes. How would this be done?
Joe Clarke Mon, 01/18/2010 - 12:57
I believe this policy will do what you want.  It requires a few environment variables to be set first:
# check_load_diff     : Integer value representing the maximum allowed
#                       rxload difference between the two interfaces.
# check_load_mins     : Number of minutes the rxload difference must be
#                       above check_load_diff before the syslog will be sent.
# check_load_int1     : First interface to check.
# check_load_int2     : Second interface to check.
# check_load_time     : Number of seconds between executions of this policy.
For example:
event manager environment check_load_diff 20
event manager environment check_load_mins 10
event manager environment check_load_int1 Serial0/0/0:0
event manager environment check_load_int2 Serial0/0/1:0
event manager environment check_load_time 60
Those values will cause the script to run every 60 seconds, and check for the conditions you described in this thread.
oschaul2 Wed, 01/20/2010 - 09:04
Thanks for your help. This worked great on a test router and one of our customer routers, but didn't work on the one customer that requested it. The one difference with their configuration is that they are using tacacs+. Would this make a difference? I wasn't able to get any information from the output interpreter.
Jan 20 10:49:32.987 CST: %HA_EM-6-LOG: tm_check_load.tcl: ..."
Jan 20 10:49:32.987 CST: %HA_EM-6-LOG: tm_check_load.tcl:     (file "system:/lib/tcl/base.tcl" line 50)
Jan 20 10:49:32.987 CST: %HA_EM-6-LOG: tm_check_load.tcl: Tcl policy execute failed: Failed to find rxload for Serial0/0/0:0 in 'Remote#'
Jan 20 10:50:33.074 CST: %HA_EM-6-LOG: tm_check_load.tcl: Failed to find rxload for Serial0/0/0:0 in 'Remote#'
Jan 20 10:50:33.074 CST: %HA_EM-6-LOG: tm_check_load.tcl:     while executing
Jan 20 10:50:33.074 CST: %HA_EM-6-LOG: tm_check_load.tcl: "get_curr_load $check_load_int1"
Jan 20 10:50:33.074 CST: %HA_EM-6-LOG: tm_check_load.tcl:     invoked from within
Jan 20 10:50:33.074 CST: %HA_EM-6-LOG: tm_check_load.tcl: "$slave eval $Contents"
Jan 20 10:50:33.074 CST: %HA_EM-6-LOG: tm_check_load.tcl:     (procedure "eval_script" line 7)
Jan 20 10:50:33.074 CST: %HA_EM-6-LOG: tm_check_load.tcl: "eval_script slave $scriptname"
Jan 20 10:50:33.078 CST: %HA_EM-6-LOG: tm_check_load.tcl:     invoked from within
Jan 20 10:50:33.078 CST: %HA_EM-6-LOG: tm_check_load.tcl: "if {$security_level == 1} {       #untrusted script
Jan 20 10:50:33.078 CST: %HA_EM-6-LOG: tm_check_load.tcl:      interp create -safe slave
Jan 20 10:50:33.078 CST: %HA_EM-6-LOG: tm_check_load.tcl:      interp share {} stdin slave
Jan 20 10:50:33.078 CST: %HA_EM-6-LOG: tm_check_load.tcl:      interp share {} stdout slave
Jan 20 10:50:33.078 CST: %HA_EM-6-LOG: tm_check_load.tcl: ..."
Jan 20 10:50:33.078 CST: %HA_EM-6-LOG: tm_check_load.tcl:     (file "system:/lib/tcl/base.tcl" line 50)
Jan 20 10:50:33.078 CST: %HA_EM-6-LOG: tm_check_load.tcl: Tcl policy execute failed: Failed to find rxload for Serial0/0/0:0 in 'Remote#'
Joe Clarke Wed, 01/20/2010 - 09:35
You need to add the following command if the device is doing command authorization:
event manager session cli username USER
Where USER is the username of a user authorized to run all of the CLI commands in the policy.
Related Content
