cefcFRUPowerOperStatus for 6500
Jan 18th, 2010
Hi all,
Having a NMS system on customer site. NMS discovered a lots of Power Supply instances on 6500 and using the following OID to get a status: cefcFRUPowerOperStatus.
It seems like most of those instances are not in normal mode(2) as you can see below. Most of them in offEnvOther state(1).
When polling instances names I get the list below. Does anybody knows what are those FRUs and why they are not in normal state. How can we change it to normal?
Sergei
[[email protected]-SMARTS-2-100R:/]$ snmpwalk -v2c -c f=ZNvAzusa 80.18.126.130 1.3.6.1.4.1.9.9.117.1.1.2.1.2
SNMPv2-SMI::enterprises.9.9.117.1.1.2.1.2.18 = INTEGER: 2
SNMPv2-SMI::enterprises.9.9.117.1.1.2.1.2.24 = INTEGER: 2
SNMPv2-SMI::enterprises.9.9.117.1.1.2.1.2.1000 = INTEGER: 2
SNMPv2-SMI::enterprises.9.9.117.1.1.2.1.2.2000 = INTEGER: 2
SNMPv2-SMI::enterprises.9.9.117.1.1.2.1.2.2007 = INTEGER: 1
SNMPv2-SMI::enterprises.9.9.117.1.1.2.1.2.2008 = INTEGER: 1
SNMPv2-SMI::enterprises.9.9.117.1.1.2.1.2.2009 = INTEGER: 1
SNMPv2-SMI::enterprises.9.9.117.1.1.2.1.2.2010 = INTEGER: 1
SNMPv2-SMI::enterprises.9.9.117.1.1.2.1.2.2011 = INTEGER: 1
SNMPv2-SMI::enterprises.9.9.117.1.1.2.1.2.2012 = INTEGER: 1
SNMPv2-SMI::enterprises.9.9.117.1.1.2.1.2.2013 = INTEGER: 1
SNMPv2-SMI::enterprises.9.9.117.1.1.2.1.2.2014 = INTEGER: 1
SNMPv2-SMI::enterprises.9.9.117.1.1.2.1.2.2015 = INTEGER: 1
SNMPv2-SMI::enterprises.9.9.117.1.1.2.1.2.2016 = INTEGER: 1
SNMPv2-SMI::enterprises.9.9.117.1.1.2.1.2.2017 = INTEGER: 1
SNMPv2-SMI::enterprises.9.9.117.1.1.2.1.2.2018 = INTEGER: 1
SNMPv2-SMI::enterprises.9.9.117.1.1.2.1.2.2019 = INTEGER: 1
SNMPv2-SMI::enterprises.9.9.117.1.1.2.1.2.2020 = INTEGER: 1
SNMPv2-SMI::enterprises.9.9.117.1.1.2.1.2.2021 = INTEGER: 1
SNMPv2-SMI::enterprises.9.9.117.1.1.2.1.2.2022 = INTEGER: 1
SNMPv2-SMI::enterprises.9.9.117.1.1.2.1.2.2023 = INTEGER: 1
SNMPv2-SMI::enterprises.9.9.117.1.1.2.1.2.2024 = INTEGER: 1
SNMPv2-SMI::enterprises.9.9.117.1.1.2.1.2.2025 = INTEGER: 1
SNMPv2-SMI::enterprises.9.9.117.1.1.2.1.2.2026 = INTEGER: 1
SNMPv2-SMI::enterprises.9.9.117.1.1.2.1.2.2027 = INTEGER: 1
SNMPv2-SMI::enterprises.9.9.117.1.1.2.1.2.2028 = INTEGER: 1
SNMPv2-SMI::enterprises.9.9.117.1.1.2.1.2.2029 = INTEGER: 1
SNMPv2-SMI::enterprises.9.9.117.1.1.2.1.2.2030 = INTEGER: 1
SNMPv2-SMI::enterprises.9.9.117.1.1.2.1.2.2031 = INTEGER: 1
SNMPv2-SMI::enterprises.9.9.117.1.1.2.1.2.2032 = INTEGER: 1
SNMPv2-SMI::enterprises.9.9.117.1.1.2.1.2.2033 = INTEGER: 1
SNMPv2-SMI::enterprises.9.9.117.1.1.2.1.2.2034 = INTEGER: 1
SNMPv2-SMI::enterprises.9.9.117.1.1.2.1.2.2035 = INTEGER: 1
SNMPv2-SMI::enterprises.9.9.117.1.1.2.1.2.2036 = INTEGER: 1
SNMPv2-SMI::enterprises.9.9.117.1.1.2.1.2.2037 = INTEGER: 1
SNMPv2-SMI::enterprises.9.9.117.1.1.2.1.2.2038 = INTEGER: 1
SNMPv2-SMI::enterprises.9.9.117.1.1.2.1.2.2039 = INTEGER: 1
SNMPv2-SMI::enterprises.9.9.117.1.1.2.1.2.2040 = INTEGER: 1
SNMPv2-SMI::enterprises.9.9.117.1.1.2.1.2.2041 = INTEGER: 1
SNMPv2-SMI::enterprises.9.9.117.1.1.2.1.2.2042 = INTEGER: 1
SNMPv2-SMI::enterprises.9.9.117.1.1.2.1.2.2043 = INTEGER: 1
SNMPv2-SMI::enterprises.9.9.117.1.1.2.1.2.2044 = INTEGER: 1
SNMPv2-SMI::enterprises.9.9.117.1.1.2.1.2.2045 = INTEGER: 1
SNMPv2-SMI::enterprises.9.9.117.1.1.2.1.2.2046 = INTEGER: 1
SNMPv2-SMI::enterprises.9.9.117.1.1.2.1.2.2047 = INTEGER: 1
SNMPv2-SMI::enterprises.9.9.117.1.1.2.1.2.2048 = INTEGER: 1
SNMPv2-SMI::enterprises.9.9.117.1.1.2.1.2.2049 = INTEGER: 1
SNMPv2-SMI::enterprises.9.9.117.1.1.2.1.2.2050 = INTEGER: 1
SNMPv2-SMI::enterprises.9.9.117.1.1.2.1.2.2051 = INTEGER: 1
SNMPv2-SMI::enterprises.9.9.117.1.1.2.1.2.2052 = INTEGER: 1
SNMPv2-SMI::enterprises.9.9.117.1.1.2.1.2.2053 = INTEGER: 1
SNMPv2-SMI::enterprises.9.9.117.1.1.2.1.2.2054 = INTEGER: 1
SNMPv2-SMI::enterprises.9.9.117.1.1.2.1.2.3000 = INTEGER: 2
SNMPv2-SMI::enterprises.9.9.117.1.1.2.1.2.4000 = INTEGER: 2
[[email protected]-SMARTS-2-100R:/]$ snmpwalk -v2c -c f=ZNvAzusa 80.18.126.130 1.3.6.1.2.1.47.1.1.1.1.7.4000
SNMPv2-SMI::mib-2.47.1.1.1.1.7.4000 = STRING: "6"
[[email protected]-SMARTS-2-100R:/]$ snmpwalk -v2c -c f=ZNvAzusa 80.18.126.130 1.3.6.1.2.1.47.1.1.1.1.7.3000
SNMPv2-SMI::mib-2.47.1.1.1.1.7.3000 = STRING: "5"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.1 = STRING: "WS-C6509"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.2 = STRING: "Physical Slot 1"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.3 = STRING: "Physical Slot 2"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.4 = STRING: "Physical Slot 3"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.5 = STRING: "Physical Slot 4"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.6 = STRING: "Physical Slot 5"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.7 = STRING: "Physical Slot 6"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.8 = STRING: "Physical Slot 7"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.9 = STRING: "Physical Slot 8"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.10 = STRING: "Physical Slot 9"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.11 = STRING: "Backplane"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.12 = STRING: "PS 1 Absent High Power Usage Sensor"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.13 = STRING: "Container of Fan FRU 1"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.14 = STRING: "fan-tray 1"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.15 = STRING: "Fan-tray 1 Status Sensor"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.16 = STRING: "Container of Container of Power Supply"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.17 = STRING: "Container of Power Supply 1"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.18 = STRING: "PS 1 PWR-4000-DC"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.19 = STRING: "PS 1 Fan Sensor"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.20 = STRING: "PS 1 Output Sensor"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.21 = STRING: "PS 1 Input Sensor"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.22 = STRING: "PS 1 Fan Incompatible Sensor"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.23 = STRING: "Container of Power Supply 2"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.24 = STRING: "PS 2 PWR-4000-DC"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.25 = STRING: "PS 2 Fan Sensor"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.26 = STRING: "PS 2 Output Sensor"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.27 = STRING: "PS 2 Input Sensor"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.28 = STRING: "PS 2 Fan Incompatible Sensor"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.29 = STRING: "Sensor for counting number of OK VTTs"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.30 = STRING: "Sensor for counting number of OK Clocks"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.31 = STRING: "Container of VTT 1"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.32 = STRING: "WS-C6K-VTT 1"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.33 = STRING: "VTT 1 OK Sensor"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.34 = STRING: "VTT 1 outlet temperature Sensor"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.35 = STRING: "Container of VTT 2"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.36 = STRING: "WS-C6K-VTT 2"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.37 = STRING: "VTT 2 OK Sensor"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.38 = STRING: "VTT 2 outlet temperature Sensor"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.39 = STRING: "Container of VTT 3"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.40 = STRING: "WS-C6K-VTT 3"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.41 = STRING: "VTT 3 OK Sensor"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.42 = STRING: "VTT 3 outlet temperature Sensor"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.43 = STRING: "Container of Clock 1"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.44 = STRING: "WS-C6000-CL 1"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.45 = STRING: "Clock 1 OK Sensor"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.46 = STRING: "Clock 1 In Using Sensor"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.47 = STRING: "Container of Clock 2"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.48 = STRING: "WS-C6000-CL 2"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.49 = STRING: "Clock 2 OK Sensor"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.50 = STRING: "Clock 2 In Using Sensor"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.1000 = STRING: "1"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.1001 = STRING: "module 1 power-output-fail Sensor"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.1002 = STRING: "module 1 insufficient cooling Sensor"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.1003 = STRING: "module 1 outlet temperature Sensor"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.1004 = STRING: "module 1 inlet temperature Sensor"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.1005 = STRING: "Gigabit Port Container 1/1"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.1006 = STRING: "Gi1/1"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.1017 = STRING: "Gigabit Port Container 1/2"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.1018 = STRING: "Gi1/2"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.1029 = STRING: "Gigabit Port Container 1/3"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.1041 = STRING: "Gigabit Port Container 1/4"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.1053 = STRING: "Gigabit Port Container 1/5"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.1065 = STRING: "Gigabit Port Container 1/6"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.1077 = STRING: "Gigabit Port Container 1/7"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.1089 = STRING: "Gigabit Port Container 1/8"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.1101 = STRING: "Gigabit Port Container 1/9"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.1113 = STRING: "Gigabit Port Container 1/10"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.1125 = STRING: "Gigabit Port Container 1/11"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.1137 = STRING: "Gigabit Port Container 1/12"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.1149 = STRING: "Gigabit Port Container 1/13"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.1161 = STRING: "Gigabit Port Container 1/14"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.1173 = STRING: "Gigabit Port Container 1/15"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.1185 = STRING: "Gigabit Port Container 1/16"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.1186 = STRING: "Gi1/16"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.2000 = STRING: "7"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.2001 = STRING: "module 7 power-output-fail Sensor"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.2002 = STRING: "module 7 insufficient cooling Sensor"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.2003 = STRING: "module 7 outlet temperature Sensor"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.2004 = STRING: "module 7 inlet temperature Sensor"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.2005 = STRING: "module 7 device-1 temperature Sensor"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.2006 = STRING: "module 7 device-2 temperature Sensor"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.2007 = STRING: "Gi7/1"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.2008 = STRING: "Gi7/2"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.2009 = STRING: "Gi7/3"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.2010 = STRING: "Gi7/4"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.2011 = STRING: "Gi7/5"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.2012 = STRING: "Gi7/6"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.2013 = STRING: "Gi7/7"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.2014 = STRING: "Gi7/8"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.2015 = STRING: "Gi7/9"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.2016 = STRING: "Gi7/10"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.2017 = STRING: "Gi7/11"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.2018 = STRING: "Gi7/12"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.2019 = STRING: "Gi7/13"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.2020 = STRING: "Gi7/14"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.2021 = STRING: "Gi7/15"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.2022 = STRING: "Gi7/16"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.2023 = STRING: "Gi7/17"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.2024 = STRING: "Gi7/18"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.2025 = STRING: "Gi7/19"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.2026 = STRING: "Gi7/20"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.2027 = STRING: "Gi7/21"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.2028 = STRING: "Gi7/22"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.2029 = STRING: "Gi7/23"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.2030 = STRING: "Gi7/24"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.2031 = STRING: "Gi7/25"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.2032 = STRING: "Gi7/26"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.2033 = STRING: "Gi7/27"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.2034 = STRING: "Gi7/28"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.2035 = STRING: "Gi7/29"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.2036 = STRING: "Gi7/30"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.2037 = STRING: "Gi7/31"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.2038 = STRING: "Gi7/32"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.2039 = STRING: "Gi7/33"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.2040 = STRING: "Gi7/34"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.2041 = STRING: "Gi7/35"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.2042 = STRING: "Gi7/36"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.2043 = STRING: "Gi7/37"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.2044 = STRING: "Gi7/38"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.2045 = STRING: "Gi7/39"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.2046 = STRING: "Gi7/40"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.2047 = STRING: "Gi7/41"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.2048 = STRING: "Gi7/42"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.2049 = STRING: "Gi7/43"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.2050 = STRING: "Gi7/44"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.2051 = STRING: "Gi7/45"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.2052 = STRING: "Gi7/46"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.2053 = STRING: "Gi7/47"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.2054 = STRING: "Gi7/48"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.3001 = STRING: "CPU of Switching Processor 5"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.3002 = STRING: "module 5 power-output-fail Sensor"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.3003 = STRING: "module 5 insufficient cooling Sensor"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.3004 = STRING: "module 5 fan-upgrade required Sensor"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.3005 = STRING: "module 5 outlet temperature Sensor"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.3006 = STRING: "module 5 inlet temperature Sensor"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.3007 = STRING: "module 5 device-1 temperature Sensor"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.3008 = STRING: "module 5 device-2 temperature Sensor"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.3009 = STRING: "module 5 asic 1 temperature Sensor"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.3010 = STRING: "module 5 asic 2 temperature Sensor"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.3011 = STRING: "module 5 asic 3 temperature Sensor"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.3012 = STRING: "module 5 asic 4 temperature Sensor"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.3013 = STRING: "module 5 asic 5 temperature Sensor"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.3014 = STRING: "module 5 asic 6 temperature Sensor"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.3015 = STRING: "MSFC Container 5"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.3016 = STRING: "msfc sub-module of 5"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.3017 = STRING: "CPU of Routing Processor 5"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.3018 = STRING: "module 5 RP outlet temperature Sensor"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.3019 = STRING: "module 5 RP inlet temperature Sensor"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.3020 = STRING: "Switching Engine Container 5"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.3021 = STRING: "switching engine sub-module of 5"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.3022 = STRING: "module 5 EARL outlet temperature Sensor"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.3023 = STRING: "module 5 EARL inlet temperature Sensor"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.3024 = STRING: "Gigabit Port Container 5/1"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.3036 = STRING: "Gigabit Port Container 5/2"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.3048 = STRING: "Gi5/2 10/100/1000BaseT"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.4001 = STRING: "CPU of Switching Processor 6"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.4002 = STRING: "module 6 power-output-fail Sensor"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.4003 = STRING: "module 6 insufficient cooling Sensor"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.4004 = STRING: "module 6 fan-upgrade required Sensor"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.4005 = STRING: "module 6 outlet temperature Sensor"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.4006 = STRING: "module 6 inlet temperature Sensor"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.4007 = STRING: "module 6 device-1 temperature Sensor"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.4008 = STRING: "module 6 device-2 temperature Sensor"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.4009 = STRING: "module 6 asic 1 temperature Sensor"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.4010 = STRING: "module 6 asic 2 temperature Sensor"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.4011 = STRING: "module 6 asic 3 temperature Sensor"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.4012 = STRING: "module 6 asic 4 temperature Sensor"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.4013 = STRING: "module 6 asic 5 temperature Sensor"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.4014 = STRING: "module 6 asic 6 temperature Sensor"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.4015 = STRING: "MSFC Container 6"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.4016 = STRING: "msfc sub-module of 6"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.4017 = STRING: "CPU of Routing Processor 6"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.4018 = STRING: "module 6 RP outlet temperature Sensor"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.4019 = STRING: "module 6 RP inlet temperature Sensor"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.4020 = STRING: "Switching Engine Container 6"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.4021 = STRING: "switching engine sub-module of 6"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.4022 = STRING: "module 6 EARL outlet temperature Sensor"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.4023 = STRING: "module 6 EARL inlet temperature Sensor"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.4024 = STRING: "Gigabit Port Container 6/1"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.4036 = STRING: "Gigabit Port Container 6/2"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.4048 = STRING: "Gi6/2 10/100/1000BaseT"
Joe Clarke Mon, 01/18/2010 - 12:13
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
These are most likely PoE ports which are not powering anything.
