MSE Password Recovery
Jan 18th, 2010
I recently got an MSE for evaluation.  When running through the script I got to a point where I was asked to change the root password.  For some unknown reason I felt inclined to do so.  I typed in a password and then confirmed it.  The only problem is when the MSE rebooted I couldn't log back into it with the password I had just typed in nor the default password.  Are there any procedures for password recovery on this piece of equipment?  I've looked but so far been unable to find anything.
Overall Rating: 5 (2 ratings)
Lucien Avramov Mon, 01/18/2010 - 09:42
MSE is running linux. To change the root password it's like on any other linux os computer, it goes via the GRUB.
The easiest would have been to use the pwd command when logged with the previous root user / pwd.
The grub method could be used again even if you cant login anymore to it. Console onto the MSE and go in the GRUB.
dhopper82 Thu, 01/21/2010 - 12:21
I tried that and after putting a 1 at the end of the line the device boots back to a login prompt.  I will attempt the console.  Are the con settings the same as a router?
Lucien Avramov Thu, 01/21/2010 - 13:26
this is a linux machine. No the passwords are not alike the router.
You have to go to GRUB to change the root password, you can do that from the console too.
