Qsig Trunk with voice gateway
Answered Question
Dear All
Recently i am helping customer  intergrate BT - Brokerage phone system with Cisco voice gateway via qsig.  My customer using Call manager 7.1 and unityconnection 2.x.  Call function between BT phone system with call manager via qsig working fine however only extension number show on BT and cisco phone.
Question:
How to allow both phone system show caller name?
Lum
Correct Answer by a.janssen about 7 years 4 months ago
Hi, what I can see is that the BT side sends Daniel Cheney as the name.
Call from BT to Cisco: Contained in Setup
Call from Cisco to BT: Contained in Connect
To get the Cisco side to send the information you have to check if an alerting name is configured on the phones line and if you filter somewhere this information out. Same for the other direction BT is sending the information, check for any accidently active filters.
Andre
Ok, I just saw that you are using H323. MGCP is best for that scenario (my experience).
Anyway you could try this with h323:
voice service voip
h323
  h225 display-ie ccm-compatible
dial peer to cucm
h225 display-ie ccm-compatible system
interface Serial0/0/0:D
isdn supp-service name calling
Andre
Overall Rating: 5 (1 ratings)
Need help for Cisco 2851 Qsig with BT PBX.
Connection between Call manager and BT PBX CUCM7.0 --> Cisco 2851 (H323) --> Qsig --> BT PBX.  Caller Name is not show from Cisco to BT and BT to Cisco.
Can someone guide me why the caller name is not show.
The following is debug from BT PBX and Cisco 2851.
From BT to Cisco
*Jan 19 04:19:31.298: ISDN Se0/0/1:15 Q931: RX <- SETUP pd = 8  callref = 0x0001
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA18381
                Preferred, Channel 1
        Facility i = 0x9FAA06800100820100A118020211F1020100800F44616E69656C20436
8656E65792C20
        Progress Ind i = 0x8183 - Origination address is non-ISDN
        Calling Party Number i = 0x0080, '6180'
                Plan:Unknown, Type:Unknown
        Called Party Number i = 0x80, '6'
*Jan 19 04:19:31.302: ISDN Se0/0/1:15 Q931: TX -> SETUP_ACK pd = 8  callref = 0x
8001
        Channel ID i = 0xA98381
                Exclusive, Channel 1
*Jan 19 04:19:31.666: ISDN Se0/0/1:15 Q931: RX <- INFORMATION pd = 8  callref =
0x0001
        Called Party Number i = 0x80, '1'
*Jan 19 04:19:31.982: ISDN Se0/0/1:15 Q931: RX <- INFORMATION pd = 8  callref =
0x0001
        Called Party Number i = 0x80, '0'
*Jan 19 04:19:32.222: ISDN Se0/0/1:15 Q931: RX <- INFORMATION pd = 8  callref =
0x0001
        Called Party Number i = 0x80, '9'
*Jan 19 04:19:32.242: ISDN Se0/0/1:15 Q931: TX -> CALL_PROC pd = 8  callref = 0x
8001
*Jan 19 04:19:32.246: ISDN Se0/0/1:15 Q931: TX -> ALERTING pd = 8  callref = 0x8
001
        Progress Ind i = 0x8188 - In-band info or appropriate now available
*Jan 19 04:19:37.002: %ISDN-6-CONNECT: Interface Serial0/0/1:0 is now connected
to 6180 N/A
*Jan 19 04:19:37.002: ISDN Se0/0/1:15 Q931: TX -> CONNECT pd = 8  callref = 0x80
01
        Connected Number i = 0x80, '6109'
*Jan 19 04:19:37.014: ISDN Se0/0/1:15 Q931: RX <- CONNECT_ACK pd = 8  callref =
0x0001
*Jan 19 04:19:43.002: %ISDN-6-CONNECT: Interface Serial0/0/1:0 is now connected
to 6180 N/A
*Jan 19 04:20:00.682: %ISDN-6-DISCONNECT: Interface Serial0/0/1:0  disconnected
from 6180 , call lasted 23 seconds
*Jan 19 04:20:00.682: ISDN Se0/0/1:15 Q931: TX -> DISCONNECT pd = 8  callref = 0
x8001
        Cause i = 0x8290 - Normal call clearing
*Jan 19 04:20:00.690: ISDN Se0/0/1:15 Q931: RX <- RELEASE pd = 8  callref = 0x00
01
*Jan 19 04:20:00.694: ISDN Se0/0/1:15 Q931: TX -> RELEASE_COMP pd = 8  callref =
0x8001
From Cisco to BT
*Jan 19 04:15:27.038: ISDN Se0/0/1:15 Q931: Applying typeplan for sw-type 0x16 i
s 0x0 0x0, Calling num 6109
*Jan 19 04:15:27.042: ISDN Se0/0/1:15 Q931: Applying typeplan for sw-type 0x16 i
s 0x0 0x0, Called num 6180
*Jan 19 04:15:27.042: ISDN Se0/0/1:15 Q931: TX -> SETUP pd = 8  callref = 0x00BE
        Sending Complete
                Standard = CCITT
        Display i = 'Noble'
        Calling Party Number i = 0x0081, '6109'
        Called Party Number i = 0x80, '6180'
*Jan 19 04:15:27.058: ISDN Se0/0/1:15 Q931: RX <- CALL_PROC pd = 8  callref = 0x
80BE
*Jan 19 04:15:27.202: ISDN Se0/0/1:15 Q931: RX <- ALERTING pd = 8  callref = 0x8
0BE
*Jan 19 04:15:31.954: ISDN Se0/0/1:15 Q931: RX <- CONNECT pd = 8  callref = 0x80
BE
        Facility i = 0x9FAA06800100820100A1180202303A020102800F44616E69656C20436
8656E65792C20
        Progress Ind i = 0x8182 - Destination address is non-ISDN
        Connected Number i = 0x0080, '6180'
*Jan 19 04:15:31.958: %ISDN-6-CONNECT: Interface Serial0/0/1:0 is now connected
to 6180 N/A
*Jan 19 04:15:31.958: ISDN Se0/0/1:15 Q931: TX -> CONNECT_ACK pd = 8  callref =
0x00BE
*Jan 19 04:15:37.958: %ISDN-6-CONNECT: Interface Serial0/0/1:0 is now connected
to 6180 N/A
*Jan 19 04:15:51.722: ISDN Se0/0/1:15 Q931: RX <- DISCONNECT pd = 8  callref = 0
x80BE
        Cause i = 0x8090 - Normal call clearing
*Jan 19 04:15:51.722: %ISDN-6-DISCONNECT: Interface Serial0/0/1:0  disconnected
from 6180 , call lasted 19 seconds
*Jan 19 04:15:51.726: ISDN Se0/0/1:15 Q931: TX -> RELEASE pd = 8  callref = 0x00
BE
*Jan 19 04:15:51.734: ISDN Se0/0/1:15 Q931: RX <- RELEASE_COMP pd = 8  callref =
0x80BE
Correct Answer
a.janssen Tue, 01/19/2010 - 10:01
Andre
voice service voip
h323
dial peer to cucm
Andre
