l2tp tunnels
Jan 18th, 2010
I have a Cisco 7200 router configured as an LNS in which they must complete a high number of L2TP tunnels.
It seems very strange that the ouput of the command "sh ip int brief", the virtual-Template appears down-down, even when I'm 35 tunnels on state "established" and are assigned Virtual-Interface
Virtual-Template212        xx.xxx.x.xxx    YES TFTP   down                  down
Another problem I encounter is that it assigns the same Virtual-Interface for different circuits. Is this normal?
23488      1201       9891       [email protected], Vi2.3 est    19:30:55 950
23504      2469       45432      [email protected], Vi2.3 est    14:24:10 271
Any idea what is happening?
This is the configuration of the Virtual Template:
interface Virtual-Template212
mtu 1501
ip unnumbered Loopback1
no ip redirects
no ip unreachables
ip mtu 1460
ip tcp adjust-mss 1420
no peer default ip address
ppp max-bad-auth 10
ppp authentication chap vpdn
Thanks for your help
Overall Rating: 5 (1 ratings)
Giuseppe Larosa Mon, 01/18/2010 - 13:41
Hello Juan,
my first impressions are:
1) normal virtual-template is used to clone, derivate the virtual-access interfaces. Virtual-access interfaces when up/up belong to active sessions
virtual-template interface can be down/down I think I've seen this.
2) it may be a way to provide scalability to overcome the problem of IDB limitations, it may be a feature and not a problem
see for example the following document to find commands to check L2TP state
Hope to help
emilio1973 Thu, 01/21/2010 - 07:20
I saw that my router has no problem So I'll start to think it is a problem from the supplier or the CPE.
