Catalyst 4900M - Interface Numbering
Jan 18th, 2010
Hello there all,
I was wondering if a interface numbering scheme is available for the 4900M.  Configuration includes 1 x 8Port 10G and 1 x 20Port 1G modules.  Would like to understand
  1. How the slots are addressed
  2. Interface Addressing
  3. TwinGig interface addressing
Hope someone can help
Jay
Overall Rating: 5 (4 ratings)
Lucien Avramov Mon, 01/18/2010 - 09:39
  • Red, 2250 points or more
Can you post your show ip int brief output?
jay.dalu-chandu... Tue, 01/19/2010 - 01:05
No, I have ordered these switches and thought that whilst waiting for delivery I will write the configurations, prepare patching/cabling schedules prepare the diagrams etc....
jay.dalu-chandu... Tue, 01/19/2010 - 01:06
Thanks, have seen that document it talks about 4500 series chassis and modules not 4900M specifically.
maxim_gorbatov Wed, 04/28/2010 - 20:26
Cisco Switch Interfaces
For Cisco Catalyst 4948 10 Gigabit Ethernet Switches and Cisco Catalyst 4900M Switches, an interface name is composed of three parts that are formatted as follows:
slot_number /port_number
The variables are as follows:
slot_number: The slot number is the number of the switch slot in which the interface module is installed. In a fixed-port configuration such as for a Cisco Catalyst 4948 10 Gigabit Ethernet Switch, the slot number is always 1. Module slots are numbered 1 to 3, from bottom to top and left to right. The Cisco Catalyst 4900M has one fixed slot, which is slot 1. The top-two half-slots are slots 2 and 3, left to right, respectively.
port_number: The port number is the number of the port on the interface module or the switch.
Hope this will help.
Maxim.
pzpgd1mlf Fri, 06/04/2010 - 14:27
So, in this case I assume the 2x10G interfaces would be Ten1/1 and Ten1/2. Thank you.
Stefan Bischoff Wed, 10/13/2010 - 05:34
Hello Jay,
the onboard 10 Gigabit interfaces are numberd as TenGigabitEthernet 1/1 up to TenGigabitEthernet 1/8. If you put the 20 Port WS-X4920-GB-RJ45 Module in the first module slot beneath the system and power LEDs, the Gigabit ports are numbered from GigabitEthernet 2/1 up to GigabitEthernet 2/20. If you plan to use TwinGig adapters, you have to use one of the TenGigabitEthernet expansion modules (4-Port WS-X4904-10GE or 8-Port WS-X4908-10GE, 2:1 overbooked), because the onboard TenGigabitEthernet interfaces does not support TwinGig adapters.
With kind regards
Stefan
I know I'm replying to an old post, but for the sake of folks getting here via google:
*May  1 14:35:06.899: %C4K_IOSMODPORTMAN-6-MODULEONLINE: Module 1 (WS-C4900M S/N: x Hw: 1.8) is online
*May  1 14:35:06.899: %C4K_IOSMODPORTMAN-6-MODULEONLINE: Module 2 (WS-X4908-10GE S/N: x Hw: 1.2) is online
*May  1 14:35:06.899: %C4K_IOSMODPORTMAN-6-MODULEONLINE: Module 3 (WS-X4920-GB-RJ45 S/N: x Hw: 1.2) is online
Module 1: Built-in 8x 10G
Module 2: Left Module
Module 3: Right Module
Note the 4908-10GE card has 16 GigE interfaces defined for use with CVR-X2-SFP= (TwinGig), counting up in port number from where the 10G interfaces left off.
Switch#show int status
Port      Name               Status       Vlan       Duplex  Speed Type
Te1/1                        notconnect   1            full    10G No X2
Te1/2                        notconnect   1            full    10G No X2
Te1/3                        notconnect   1            full    10G No X2
Te1/4                        notconnect   1            full    10G No X2
Te1/5                        notconnect   1            full    10G No X2
Te1/6                        notconnect   1            full    10G No X2
Te1/7                        notconnect   1            full    10G No X2
Te1/8                        notconnect   1            full    10G No X2
Te2/1                        notconnect   1            full    10G No X2
Te2/2                        notconnect   1            full    10G No X2
Te2/3                        notconnect   1            full    10G No X2
Te2/4                        notconnect   1            full    10G No X2
Te2/5                        notconnect   1            full    10G No X2
Te2/6                        notconnect   1            full    10G No X2
Te2/7                        notconnect   1            full    10G No X2
Te2/8                        notconnect   1            full    10G No X2
Gi2/9                        inactive     1            full   1000 No Gbic
Gi2/10                       inactive     1            full   1000 No Gbic
Gi2/11                       inactive     1            full   1000 No Gbic
Gi2/12                       inactive     1            full   1000 No Gbic
Gi2/13                       inactive     1            full   1000 No Gbic
Gi2/14                       inactive     1            full   1000 No Gbic
Gi2/15                       inactive     1            full   1000 No Gbic
Gi2/16                       inactive     1            full   1000 No Gbic
Gi2/17                       inactive     1            full   1000 No Gbic
Gi2/18                       inactive     1            full   1000 No Gbic
Gi2/19                       inactive     1            full   1000 No Gbic
Gi2/20                       inactive     1            full   1000 No Gbic
Gi2/21                       inactive     1            full   1000 No Gbic
Gi2/22                       inactive     1            full   1000 No Gbic
Gi2/23                       inactive     1            full   1000 No Gbic
Gi2/24                       inactive     1            full   1000 No Gbic
Gi3/1                        notconnect   1            auto   auto 10/100/1000-TX
Gi3/2                        notconnect   1            auto   auto 10/100/1000-TX
Gi3/3                        notconnect   1            auto   auto 10/100/1000-TX
Gi3/4                        notconnect   1            auto   auto 10/100/1000-TX
Gi3/5                        notconnect   1            auto   auto 10/100/1000-TX
Gi3/6                        notconnect   1            auto   auto 10/100/1000-TX
Gi3/7                        notconnect   1            auto   auto 10/100/1000-TX
Gi3/8                        notconnect   1            auto   auto 10/100/1000-TX
Gi3/9                        notconnect   1            auto   auto 10/100/1000-TX
Gi3/10                       notconnect   1            auto   auto 10/100/1000-TX
Gi3/11                       notconnect   1            auto   auto 10/100/1000-TX
Gi3/12                       notconnect   1            auto   auto 10/100/1000-TX
Gi3/13                       notconnect   1            auto   auto 10/100/1000-TX
Gi3/14                       notconnect   1            auto   auto 10/100/1000-TX
Gi3/15                       notconnect   1            auto   auto 10/100/1000-TX
Gi3/16                       notconnect   1            auto   auto 10/100/1000-TX
Gi3/17                       notconnect   1            auto   auto 10/100/1000-TX
Gi3/18                       notconnect   1            auto   auto 10/100/1000-TX
Gi3/19                       notconnect   1            auto   auto 10/100/1000-TX
Gi3/20                       notconnect   1            auto   auto 10/100/1000-TX
Switch#
alsarinetworks Wed, 08/05/2015 - 05:22
Very useful.  A simple topic but very difficult find out clear information about this.
Related Content
