01-18-2010 10:59 AM - edited 03-06-2019 09:20 AM
I want to offer the contract to a firm contains a central switch with the following specifications
Flash = 8 MB
SDRAM = 64 MB
switching capacity = 48G
support L2 and L3
Forwording rate 34M
support 16K mac address table
What is the equivalent switch from Cisco for this purpose and achieve the conditions .
thanks all
01-18-2010 01:14 PM
Sounds like you are looking at at Sup720 with a 6748 line card for a 48Gig switching capacity.
01-19-2010 06:46 AM
I thank maybe the switch match the specifications 4948 ??
01-19-2010 08:17 AM
4948 will fulfill all requirements with the exception of the flash and sdram
Flash memory: 64 MB
SDRAM: 256 MB
Edison
01-19-2010 09:10 AM
OK i see that , but the switch 6748 more Expensive from 4948
and the switch 4948 Achieve the desired and more .
01-19-2010 09:15 AM
Actually if you want 48Gbps at wire speed then the 6500 will not provide this because a 6478 line card has 48 ports capable of running at1Gbps but it has a 40Gbps connection to the switch fabric so there could be oversubscription. The 4948 is true wire speed.
Whether or not you can get oversubscription is another question altogether.
Jon
