Help in the Problem
Jan 18th, 2010
Dear All,
I am new in this group, I need some help from Cisco Expert Friends. I Just need scenario to configure Redundancy and Load Balancing between two ISP. My Present Network Daigrame.
1. Two Router with 3 No's of Interfaces (1WAN, 2LAN). Each Router have 3 Interface. (1 For Wan, 2&3 For CoreSwitches)
2. Two Core Switches with redundancy using Cascading Cable.
So i need to make Redundancy and Load Balancing using this scenerio.
Please Help in this scenerio to:
--What Protocol i have to used for redundancy and load balancing.
--Its better to send any link so i can read and implement.
Please do needful help as soon as possible.
regards, [email protected]
Giuseppe Larosa Mon, 01/18/2010 - 13:24
  • Hall of Fame,
    Founding Member
may you provide additional details like:
router platforms models, type of links (GE, FE and so on) type of connectivity to WAN, routing protocol on WAN (if any)
core switches model ( it is a stack ? are you trying to say that with cascading cable ????)
depending on these details a good solution can be found.
OSPF or EIGRP can be good choices for your environment but what the core switches are (if they can be treated as single box or not) is important too.
Hope to help
Giuseppe
