A simple IOS upgade question
Answered Question
Jan 18th, 2010
     I have 2851 router running 12.4(4)XC6, I want to upgrde to 12.4-24.T2.  I have both images on my router's flash  I removed the old boot system flash command and created a new one; "boot system flash c2800nm-adventerprisek9-mz.124-24.T2.bin".  When I reboot the router will always return to the 12.4(4)XC6 image.  I'd rather not remove the old code as this is a remote site and it will be a huge problem to get the router restored.  The confreg is set to 0x2102.  Is there a way to force the router to boot to the new image?  Thanks in advance!
dir
Directory of flash:/
    1  -rw-    39715748  Jan 18 2010 10:12:12 -05:00  c2800nm-adventerprisek9-mz.124-4.XC6.bin
    2  -rw-    59455672  Jan 18 2010 15:05:24 -05:00  c2800nm-adventerprisek9-mz.124-24.T2.bin
129748992 bytes total (30572544 bytes free)
Correct Answer by Jon Marshall about 7 years 7 months ago
cbreger_breger wrote:
I've tried all suggestions and saved the config several times, the router continues to come back to the old image.  The commands "show boot or show bootvar" do not work on the router.  Any other ideas?
sh run | i boot
boot-start-marker
boot system flsh:c2800nm-adventerprisek9-mz.124-24.T2.bin
boot-end-marker
Is the above output from the actual router ? if so you have a typo ie. flsh instead of flash
Jon
Overall Rating: 5 (1 ratings)
Leo Laohoo Mon, 01/18/2010 - 13:04
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Try "boot system flash:c2800nm-adventerprisek9-mz.124-24.T2.bin" OR copy the old IOS to your TFTP, delete the old IOS from the CF and copy the old IOS back.  Make sure the IOS is found BELOW the new IOS.
Jerry Ye Mon, 01/18/2010 - 13:06
  • Cisco Employee,
Just did a quick test in my lab routers, and I am able to boot it off the new image while leave the old image in the flash. Here is the show output
Rack1R1#sh ver | i System|Config
Copyright (c) 1986-2009 by Cisco Systems, Inc.
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
System returned to ROM by reload at 20:58:11 UTC Mon Jan 18 2010
System restarted at 21:00:14 UTC Mon Jan 18 2010
System image file is "flash:c2800nm-adventerprisek9-mz.124-15.T10.bin"
Rack1R1#sh run | s boot
boot-start-marker
boot system flash c2800nm-adventerprisek9-mz.124-15.T10.bin
boot-end-marker
Rack1R1#dir
    1  -rw-    53139536  Sep 11 2009 19:38:06 +00:00  c2800nm-adventerprisek9-mz.124-15.T9.bin
    2  -rw-    53185960  Sep 24 2009 18:48:04 +00:00  c2800nm-adventerprisek9-mz.124-15.T10.bin
256471040 bytes total (150142976 bytes free)
Rack1R1#
My question to you is did you do a wri mem before reboot?
jerry
kumarkrishnar Mon, 01/18/2010 - 21:00
After config boot commad for new IOS do write mem and check the next boot loader
using show boot or show bootvar
this will display the next ios image if it is psssible u can past the outout here we can validate the same
thank you
regards
krishna kumar
cbreger_breger Tue, 01/19/2010 - 05:37
sh run | i boot
boot-start-marker
boot-end-marker
Correct Answer
Jon Marshall Tue, 01/19/2010 - 05:47
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
sh run | i boot
boot-start-marker
boot-end-marker
Jon
