NAC and Allowing NFS Mounts
Jan 18th, 2010
When a linux system boots, the 'root' processes typically attempts to mount network drives via NFS, prior to any user login on the system. In NAC, is it sufficient to add in the User Roles->Traffic Control->Unathenticated Role allowing TCP/UDP ports 111 & 2049 for the NFS mount process to work? We're using NAC v4.7.1
Doug
Faisal Sehbai Sat, 01/23/2010 - 20:23
  • Gold, 750 points or more
Doug,
If those two ports are what your NFS uses, then yes, opening them up in Unauthenticated role should be sufficient!
HTH,
Faisal
Related Content
