IP Telephony-DND & Extension Mobility:
Jan 18th, 2010
Hallo,
Am deploying IP telephony and am having the following issues:
1.Extension Mobility-Extension mobility works fine,user are able to log  in and log out of their phones without any  problem,the only issue is the phones  reset completely when a user logs out and when a user logs in.What could be the problem?Am using IP addresses instead of DNS for extension mobility.
2.DND-DND works ok,the problem is when a user presses the DND softkey,the phones should show a message like "DND is active"-in my case what is showing is "????"-how do i custom this so that it displays  a message like:"DND is active".
Please help on the issues above.
Nicholas.
Koiser_Nicholas Tue, 01/19/2010 - 09:10
Hi guys,
managed to resolve both of these issues,it was an issues with the phone firmware-i downgraded and then upgraded the firmware and then it worked ok.
Nick.
