Redirect web traffic to external proxy in a specific port
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
01-19-2010 12:46 AM - edited 03-04-2019 07:14 AM
Hi, I want to redirect internal web traffic (browsing) to an external web server for Web, Virus and Spyware filtering. Those externals proxies are running in 8080 port. I have one ASA firewall and a Cisco 2600 router. I was thinking in doing PBR in the router but in the next hop I can only set one IP, not an IP and a port.
So how can I redirect web traffic to an external proxy listening in 8080 port?
- Labels:
Other Routing
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
01-19-2010 12:55 AM
In your PBR, match tcp port 8080 and set the nexthop accordingly, bellow is an example:
route-map PBR permit 10
match ip address 100
set ip next-hop x.x.x.x
access-list 100 permit tcp any any eq 8080
Mohamed
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
01-19-2010 01:00 AM
No, I need to redirect web (port 80) traffic to an external proxy server listening in 8080. Not 8080 traffic to an external server. Do you understand?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
05-30-2014 12:55 AM
you need "GRE tunnel" between ur proxy and ur router
and then u can use PBR next hop.
regards
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
05-30-2014 12:57 AM
i belive that on cisco routers we cant nat the destination ,
we just can nat the source
i dont know cisco why it dontdo that !! , it do that on ASA firewalls
but i found that linux can do both (src ,dst) nat !!
regards
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
01-19-2010 01:15 AM
you will need to modify the Access-list to:
access-list 100 permit tcp any any eq www
Regarding the proxy, it should be listining on port 80 as well so that the traffic gets to it.
You dont need additional config, if the proxy is listining on port 80
Mohamed
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
01-19-2010 01:24 AM
Yes, but the proxy is an external server and is listening in port 8080. I can't change the port where it is listening
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
01-19-2010 07:55 AM
You can use static NAT.
On the router, configure the following:
ip nat inside source static tcp 10.1.100.1 8080 10.1.100.1 80 extendable
where the proxy IP address doesn't change, just the TCP port.
On the interface towards the Proxy server, you need ip nat inside
On the interface towards the clients, you need ip nat outside
Be aware, you can't perform internet NAT on this device and the ASA can be used for internet NAT for your network.
I did a quick lab to test this concept:
R2 (acting as client) <------>R0 (acting as NAT router)<----->R1(acting as proxy listening on port 8080).
R1:
R1#sh run | i http
ip http server
ip http port 8080
no ip http secure-server
R1#sh ip http server status | i 8080
HTTP server port: 8080
Before implementing the NAT, I can only access R1 when telnetting to port 8080 from R2.
It won't work when trying port 80.
R2#telnet 10.1.100.1 80
Trying 10.1.100.1, 80 ...
% Connection refused by remote host
R2#telnet 10.1.100.1 8080
Trying 10.1.100.1, 8080 ... Open
HTTP/1.1 400 Bad Request
Date: Tue, 19 Jan 2010 10:45:16 GMT
Server: cisco-IOS
Accept-Ranges: none
400 Bad Request
I implemented the NAT on R0
% Connection timed out; remote host not responding
R2#
R2#
Trying 10.1.100.1, 80 ... Open
^^xx
Date: Tue, 19 Jan 2010 10:46:28 GMT
Server: cisco-IOS
Accept-Ranges: none
400 Bad Request
R0#sh ip nat tr
Pro Inside global Inside local Outside local Outside global
tcp 10.1.100.1:80 10.1.100.1:8080 --- ---
R0#
Edison
Edit: If you want to use this router for internet NAT, you can change the outside|inside designation on the interfaces and also change the command from
to
ip nat outside source static tcp 10.1.100.1 8080 10.1.100.1 80 extendable
Message was edited by: Edison Ortiz
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
01-22-2010 01:10 AM
Ok, that's fine.
But now I am not able to redirect traffic to that external server. I'm testing with PBR next-hop but it seems that is taking the default-route.
The proxy is on the Internet, is not directly connected to my network. I do not know if the next-hop has to indicate an ip directly connected or not.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
01-22-2010 11:48 AM
I understand your requirements. I believe you will accomplish this task a lot easier if you send the proxy configuration to workstations either via DHCP or a PAC file.
http://en.wikipedia.org/wiki/Proxy_auto-config
http://en.wikipedia.org/wiki/Web_Proxy_Autodiscovery_Protocol
Edison
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
01-25-2010 02:49 AM
ok, but i'd like to control at network level. Do you know if there is a command to send traffic through an specific internet router? Do you know if with next-hop command you can only set a directly connected router?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
01-26-2010 01:17 PM
I haven't tested this concept but it seems that's what you are after
https://www.cisco.com/en/US/docs/ios/12_0s/feature/guide/12s_pbr.html
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
01-27-2010 01:38 AM
My router (2600) doesn't support it. Thanks anyway. Maybe it's time to renew
